소개
Keep your iMac cool and happy by replacing the upper right fan.
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
Disconnect the upper right fan cable connector from the logic board by pulling its connector straight up.
다른 한 분이 해당 안내서를 완성하였습니다.
