주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac G5 17" Model A1144 Hard Drive Replacement
필요한 것
    1. iMac G5 17" Model A1144 Hard Drive Replacement, Access Door: 1 단계, 이미지 1개 중 1개
      • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
      • Loosen the two Phillips screws securing the access door to your iMac.
      • These screws are captive in the access door.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the access door from your iMac.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Hard Drive Replacement, Front Bezel: 3 단계, 이미지 1개 중 1개
      • Remove the three T8 Torx screws securing the front bezel to the rear panel.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
      • Orient the iMac face-up, on its backside.
      • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
      • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 iMac G5 17" Model A1144 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 iMac G5 17" Model A1144 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Re-orient your iMac so it sits upright on the stand.
      • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
      • Push the card toward the top of the iMac to release the front bezel latch.
      • Pull the front bezel away from the rear case.
      • Repeat this process for the other side of the front bezel.
      • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
      • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
      댓글 쓰기
    5. iMac G5 17" Model A1144 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
      • Lay your iMac stand-side down on a table.
      • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
      • Lay the front bezel above the rest of the iMac.
      댓글 쓰기
    6. iMac G5 17" Model A1144 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
      • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
      댓글 쓰기
    7. iMac G5 17" Model A1144 Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
      • Disconnect both the camera and microphone cables.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Hard Drive Replacement, Display: 10 단계, 이미지 1개 중 1개
      • Peel back the aluminum EMI shield up off the lower three edges of the rear case.
      • It is not necessary to peel the EMI shield off the display.
      • We found it helpful to tape the EMI shield up against the display to keep it out of the way.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Hard Drive Replacement: 11 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Hard Drive Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board.
      • Using its attached black tab, pull the display data cable connector up off the logic board.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Hard Drive Replacement: 12 단계, 이미지 1개 중 1개
      • Pull the inverter cable connector up off its socket on the logic board.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Hard Drive Replacement: 13 단계, 이미지 1개 중 1개
      • Peel back the aluminum EMI tape from the two vertical edges of the display.
      • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
      댓글 쓰기
    5. iMac G5 17" Model A1144 Hard Drive Replacement: 14 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Hard Drive Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case.
      • These screws are recessed, so a thin screwdriver such as this is essential for removal. Bit drivers tend to be too short for this application.
      댓글 쓰기
    6. iMac G5 17" Model A1144 Hard Drive Replacement: 15 단계, 이미지 1개 중 1개
      • Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
      • Be mindful of any cables that may get caught during removal.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Hard Drive Replacement, Hard Drive: 16 단계, 이미지 1개 중 1개
      • Disconnect the hard drive thermal sensor by pulling the connector away from its socket parallel to the face of the hard drive.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Hard Drive Replacement: 17 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Hard Drive Replacement: 17 단계, 이미지 2개 중 2개
      • Pressing the top of the hard drive bracket down to release it from the rear case requires a substantial amount of force, so we recommend laying your iMac stand-side down on a table to avoid knocking it over.
      • Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself.
      • Lift the hard drive off its lower pins and pull it out of the rear case, minding the cables that are still attached.
      • When reinstalling the hard drive, be careful not to push the rubber grommets through the chassis with the hard drive pins as retrieving them may require logic board removal.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Hard Drive Replacement: 18 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Hard Drive Replacement: 18 단계, 이미지 2개 중 2개
      • Insert the flat end of a spudger into the gap between the SATA power connector and the hard drive.
      • Twist the spudger to separate the SATA power connector from the hard drive.
      • Pull the SATA power connector away from the hard drive.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Hard Drive Replacement: 19 단계, 이미지 1개 중 1개
      • Pull the SATA data cable away from the hard drive.
      • Hard drive remains.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Hard Drive Replacement, Hard Drive: 20 단계, 이미지 1개 중 1개
      • Remove the two T8 Torx screws securing the upper bracket to the hard drive.
      • Transfer the bracket and screws to your new hard drive.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Hard Drive Replacement: 21 단계, 이미지 1개 중 1개
      • Remove the two T8 Torx pins on the connector side of the hard drive and transfer them to your new hard drive.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Hard Drive Replacement: 22 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the hard drive thermal sensor off the hard drive.
      • Don't forget to transfer this to your new drive.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 112명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Walter Galan
710,644 평판
안내서 1,203개를 작성함
4가이드 댓글
I disconnected the hard drive bracket and slid it to one side and removed it, then removed the hard drive (squeezing it out just wasn't working for me).
tina - 답글 공유
Before I discovered IFIXIT I had purchased a hard drive from Western Digital and am hoping it is the correct one for my 17" iMac G5, 2 GHz Intel Core 2 Duo. The WD drive's description is TRESXLB2 7200 64M SATA3 6GB/S 1.0 TB 2HD STD . Can anyone tell me if I will have problems with this drive? Western Digital's recommendations fit this description for my iMac. Thank you. Ron
ronliz3 - 답글 공유
Excellent presentation. My iMac G5 came apart easily just as described. The unit still worked perfectly but had been on the shelf for years as the screen was almost blacked out with lines. The G5 was replaced with an Intel model but I miss certain aspects of the old system. I'm hoping the HDD will boot up a G5 Power Mac so I can reminisce!
James Bonnefin - 답글 공유
Excellent guideline. I took apart my old iMac to use the hard drive with the docking. Spend only few minutes with my daughter read the instructions, its quite fun. Thank you Walter. Keep safe and healthy
Tri Hadi Kurniawan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 87
전체 시간: 77,846
