주요 콘텐츠로 건너뛰기
iPad Pro 9.7" Screen Replacement
필요한 것
  1. iPad Pro 9.7" Screen Replacement, iPad Pro 9.7" Opening Procedure: 1 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement, iPad Pro 9.7" Opening Procedure: 1 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement, iPad Pro 9.7" Opening Procedure: 1 단계, 이미지 3개 중 3개
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Pro 9.7" Screen Replacement: 2 단계, 이미지 1개 중 1개
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
  3. iPad Pro 9.7" Screen Replacement: 3 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 3 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 3 단계, 이미지 3개 중 3개
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
  4. iPad Pro 9.7" Screen Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  5. iPad Pro 9.7" Screen Replacement: 5 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 5 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPad Pro 9.7" Screen Replacement: 6 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
  7. iPad Pro 9.7" Screen Replacement: 7 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 7 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  8. iPad Pro 9.7" Screen Replacement: 8 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 8 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Don't insert the pick past the bezel into the display area, or you will damage it.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch into the iPad.
  9. iPad Pro 9.7" Screen Replacement: 9 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Insert a second opening pick by the front-facing camera.
  10. iPad Pro 9.7" Screen Replacement: 10 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 10 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  11. iPad Pro 9.7" Screen Replacement: 11 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Insert a third pick by the front-facing camera.
  12. iPad Pro 9.7" Screen Replacement: 12 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 12 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Bring the right opening pick down and around the top right corner of the iPad.
  13. iPad Pro 9.7" Screen Replacement: 13 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 13 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Bring the left opening pick around the top left corner of the tablet.
  14. iPad Pro 9.7" Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  15. iPad Pro 9.7" Screen Replacement: 15 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 15 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 15 단계, 이미지 3개 중 3개
    • Slide the right opening pick roughly halfway down the display.
  16. iPad Pro 9.7" Screen Replacement: 16 단계, 이미지 1개 중 1개
    • Reheat the iOpener and apply heat to the left side of the iPad.
  17. iPad Pro 9.7" Screen Replacement: 17 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 17 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 17 단계, 이미지 3개 중 3개
    • Slide the left-hand opening pick about halfway down the edge of the display.
  18. iPad Pro 9.7" Screen Replacement: 18 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 18 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 18 단계, 이미지 3개 중 3개
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
  19. iPad Pro 9.7" Screen Replacement: 19 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 19 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 19 단계, 이미지 3개 중 3개
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
  20. iPad Pro 9.7" Screen Replacement: 20 단계, 이미지 1개 중 1개
    • Use the iOpener to apply heat to the bottom edge of the iPad.
  21. iPad Pro 9.7" Screen Replacement: 21 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 21 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 21 단계, 이미지 3개 중 3개
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  22. iPad Pro 9.7" Screen Replacement: 22 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 22 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 22 단계, 이미지 3개 중 3개
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed.
  23. iPad Pro 9.7" Screen Replacement: 23 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 23 단계, 이미지 2개 중 2개
    • Remove the right-hand opening pick at the bottom of the iPad.
  24. iPad Pro 9.7" Screen Replacement: 24 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 24 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 24 단계, 이미지 3개 중 3개
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than a quarter inch into the display to avoid damaging the Home Button and display cables underneath.
  25. iPad Pro 9.7" Screen Replacement, Slice through the remaining adhesive: 25 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement, Slice through the remaining adhesive: 25 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement, Slice through the remaining adhesive: 25 단계, 이미지 3개 중 3개
    • Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
    • Twist the top and bottom picks to separate the display assembly from the rear case.
    • Do not attempt to remove the display—it is still attached to the rear case.
  26. iPad Pro 9.7" Screen Replacement: 26 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 26 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 26 단계, 이미지 3개 중 3개
    • Swing the display assembly towards the right of the case, using the right edge as a hinge.
    • As you move the display assembly, make sure that the display ribbon cable is not being stressed.
    • Continue swinging the display assembly until it lays flat next to the rear case.
  27. iPad Pro 9.7" Screen Replacement, Disconnect the battery: 27 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
  28. iPad Pro 9.7" Screen Replacement: 28 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the EMI shield on the logic board for one minute.
  29. iPad Pro 9.7" Screen Replacement: 29 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 29 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 29 단계, 이미지 3개 중 3개
    • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
    • Slowly peel the EMI shield up from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Remove the logic board EMI shield.
  30. iPad Pro 9.7" Screen Replacement: 30 단계, 이미지 1개 중 1개
    • Use a Phillips driver to remove the 1.7 mm-long screw securing the battery connector.
  31. iPad Pro 9.7" Screen Replacement: 31 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 31 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 31 단계, 이미지 3개 중 3개
    • If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield.
    • Squeeze the sharp protrusion with a pair of pliers to flatten it.
    • Repeat the process for all sharp protrusions along the edges of the EMI shield.
  32. iPad Pro 9.7" Screen Replacement, Battery connector information: 32 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement, Battery connector information: 32 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement, Battery connector information: 32 단계, 이미지 3개 중 3개
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  33. iPad Pro 9.7" Screen Replacement, Disconnect the battery: 33 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement, Disconnect the battery: 33 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement, Disconnect the battery: 33 단계, 이미지 3개 중 3개
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the left side of the logic board's battery connector at a 35 degree angle.
    • The battery blocker's right prong should slide between the left side of the logic board's battery connector and the battery's contact pads. The left prong should slide under the logic board.
    • Don't push the battery blocker underneath the connector or logic board with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, refer to the next step for information on loosening the logic board. You can also try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card should slide under the logic board without encountering any blockages. After insertion, they should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
  34. iPad Pro 9.7" Screen Replacement, Logic board adhesive information: 34 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement, Logic board adhesive information: 34 단계, 이미지 2개 중 2개
    • If the battery blocker doesn't easily slide under the logic board, follow these steps to partially loosen the logic board from the frame:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the logic board to the left and right of the battery connection.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the logic board.
    • Try to insert the battery blocker. If the logic board doesn't easily lift up, apply a few more drops of isopropyl alcohol.
    • This doesn't apply when using the playing card method to disconnect the battery because the playing card is only inserted between the battery connector and the battery contact pads.
  35. iPad Pro 9.7" Screen Replacement, Remove the display bracket screws: 35 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
  36. iPad Pro 9.7" Screen Replacement, Remove the bracket: 36 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement, Remove the bracket: 36 단계, 이미지 2개 중 2개
    • Remove the display cable bracket.
  37. iPad Pro 9.7" Screen Replacement, Disconnect the display assembly: 37 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement, Disconnect the display assembly: 37 단계, 이미지 2개 중 2개
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  38. iPad Pro 9.7" Screen Replacement: 38 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 38 단계, 이미지 2개 중 2개
    • Repeat the previous step for the two remaining connectors.
  39. iPad Pro 9.7" Screen Replacement, Remove the display assembly: 39 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement, Remove the display assembly: 39 단계, 이미지 2개 중 2개
  40. iPad Pro 9.7" Screen Replacement, Disconnect the home button: 40 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement, Disconnect the home button: 40 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the tape covering the ZIF connector above the home button.
  41. iPad Pro 9.7" Screen Replacement: 41 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 41 단계, 이미지 2개 중 2개
    • Use the point of a spudger to lift the flap on the ZIF connector that secures the cable.
  42. iPad Pro 9.7" Screen Replacement: 42 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 42 단계, 이미지 2개 중 2개
    • Use tweezers to slide the cable out of the ZIF connector.
  43. iPad Pro 9.7" Screen Replacement, Loosen the home button: 43 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement, Loosen the home button: 43 단계, 이미지 2개 중 2개
    • The home button's ribbon cable is very fragile. If it gets damaged, Touch ID will no longer function.
    • Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up.
    • Alternatively, apply a few drops of isopropyl alcohol to the cable and wait for a minute to let the adhesive soften.
  44. iPad Pro 9.7" Screen Replacement: 44 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement: 44 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement: 44 단계, 이미지 3개 중 3개
    • Starting from the ZIF connector, use an opening pick to separate the home button cable from the adhesive holding it in place. Stop when you reach the home button.
  45. iPad Pro 9.7" Screen Replacement, Remove the home button bracket: 45 단계, 이미지 3개 중 1개 iPad Pro 9.7" Screen Replacement, Remove the home button bracket: 45 단계, 이미지 3개 중 2개 iPad Pro 9.7" Screen Replacement, Remove the home button bracket: 45 단계, 이미지 3개 중 3개
    • The home button bracket is held in place with strong adhesive.
    • Apply a few drops of isopropyl alcohol to the base of the home button bracket.
    • Alternatively, you can use a heated iOpener to loosen the adhesive.
  46. iPad Pro 9.7" Screen Replacement: 46 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement: 46 단계, 이미지 2개 중 2개
    • Insert the edge of an opening tool under the home button bracket lip.
    • Pry up with steady force to loosen the bracket.
    • The adhesive holding this bracket can be stubborn. Apply more isopropyl alcohol or heat if it doesn't budge.
  47. iPad Pro 9.7" Screen Replacement: 47 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Remove the home button bracket.
    • Be careful when you remove the home button bracket. There may be a small plastic washer wedged between the bracket and the button. If there is, be sure to retain this washer for reinstallation.
    • During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it.
    • Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high concentration (>90%) isopropyl alcohol.
    • Secure the bracket with E6000 glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
  48. iPad Pro 9.7" Screen Replacement, Remove the home button: 48 단계, 이미지 2개 중 1개 iPad Pro 9.7" Screen Replacement, Remove the home button: 48 단계, 이미지 2개 중 2개
    • Gently push the home button from the front of the display inward using the tip of a finger.
  49. iPad Pro 9.7" Screen Replacement: 49 단계, 이미지 1개 중 1개
    • Remove the home button.
    • The home button attaches to the screen with an adhesive gasket. When you transfer the home button to a new display, use some liquid adhesive to glue the button perimeter to the screen.
결론
Compare your new replacement part to the original part. You may need to transfer remaining components (such as the camera bezel) or remove adhesive backings from the new part before installing.
To reassemble your device, follow the above steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Repair didn’t go as planned? Check out our iPad Pro 9.7” Answers community for troubleshooting help.
다른 40명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
314,154 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,790개를 작성함
18가이드 댓글
How would you re-attach that EMI shield after it has been peeled off?
Garrett Coyle - 답글
Hi Garrett,
Try to straighten it as much as possible and remove any jagged edges around the edges. The screws will hold the shield in place.
Arthur Shi -
I have a broken glass cover on the LCD screen on my iPad pro 9.7, is it possible to just replace the glass?
Esko Ala-Nisula - 답글
It is possible, although extremely difficult. You will need to remove the lcd/digitizer without doing any damage to the lcd. Then you need to separate the lcd from the cracked digitizer, clean the lcd, and then glue the lcd to the new digitizer. The fact that your asking this leads me to believe that you don’t have the many expensive machines and supplies to complete this correctly. I would just replace the lcd, as there is a fair chance you will damage it doing this removal anyways - depending on your skill level.
Hope this helps!
Steve Noah -
Doing a screen replacement, I followed the instructions but, it won’t come back on no picture and I don’t think its the back light because i shined a light on it and I can’t see anything. It will charge but no picture, tried the original broken screen and two others. Any Ideas?
Zachary Swagger - 답글
댓글 쓰기
조회 통계:
지난 24시간: 34
지난 7일: 330
지난 30일: 1,382
전체 시간: 95,601
