주요 콘텐츠로 건너뛰기
iPhone 11 Logic Board Replacement
필요한 것
동영상 개요
  1. iPhone 11 Logic Board Replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 2개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 11 Logic Board Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 11 Logic Board Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 3개
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 11 Logic Board Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 11 Logic Board Replacement: 5 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement: 5 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 11 Logic Board Replacement: 6 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement: 6 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement: 6 단계, 이미지 3개 중 3개
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 11 Logic Board Replacement, Heat the lower edge of the phone: 7 단계, 이미지 1개 중 1개
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
  8. iPhone 11 Logic Board Replacement: 8 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement: 8 단계, 이미지 2개 중 2개
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone 11 Logic Board Replacement, Lift the display slightly: 9 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Lift the display slightly: 9 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Lift the display slightly: 9 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 11 Logic Board Replacement, Separate the screen adhesive: 10 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Separate the screen adhesive: 10 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Separate the screen adhesive: 10 단계, 이미지 3개 중 3개
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 11 Logic Board Replacement, Screen information: 11 단계, 이미지 1개 중 1개
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone 11 Logic Board Replacement: 12 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement: 12 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement: 12 단계, 이미지 3개 중 3개
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 11 Logic Board Replacement: 13 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement: 13 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement: 13 단계, 이미지 3개 중 3개
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  14. iPhone 11 Logic Board Replacement: 14 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement: 14 단계, 이미지 2개 중 2개
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
  15. iPhone 11 Logic Board Replacement, Remove the suction cup: 15 단계, 이미지 1개 중 1개
    • Pull the small nub on the suction cup to detach it from the front panel.
  16. iPhone 11 Logic Board Replacement, Open the iPhone: 16 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Open the iPhone: 16 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Open the iPhone: 16 단계, 이미지 3개 중 3개
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 11 Logic Board Replacement, Display Assembly: 17 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Display Assembly: 17 단계, 이미지 2개 중 2개
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
  18. iPhone 11 Logic Board Replacement, Unscrew the battery connector cover: 18 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Unscrew the battery connector cover: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 11 Logic Board Replacement, Remove the battery connector cover: 19 단계, 이미지 1개 중 1개
    • Remove the bracket.
  20. iPhone 11 Logic Board Replacement, Disconnect the battery: 20 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the battery: 20 단계, 이미지 2개 중 2개
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  21. iPhone 11 Logic Board Replacement, Unscrew the logic board cover screws: 21 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Unscrew the logic board cover screws: 21 단계, 이미지 2개 중 2개
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
  22. iPhone 11 Logic Board Replacement, Remove the logic board cover bracket: 22 단계, 이미지 1개 중 1개
  23. iPhone 11 Logic Board Replacement, Disconnect the display: 23 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the display: 23 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Disconnect the display: 23 단계, 이미지 3개 중 3개
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
  24. iPhone 11 Logic Board Replacement, Disconnect the front sensors: 24 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the front sensors: 24 단계, 이미지 2개 중 2개
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  25. iPhone 11 Logic Board Replacement, Remove the display assembly: 25 단계, 이미지 1개 중 1개
  26. iPhone 11 Logic Board Replacement, Unscrew the rear camera cover: 26 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Unscrew the rear camera cover: 26 단계, 이미지 2개 중 2개
    • Remove the two Phillips screws securing the rear camera cover:
    • One 1.4 mm screw
    • One 1.3 mm screw
  27. iPhone 11 Logic Board Replacement, Remove the camera cover: 27 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Remove the camera cover: 27 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Remove the camera cover: 27 단계, 이미지 3개 중 3개
    • Lift the camera cover from the edge closest to the battery, and remove it.
    • To reinstall the camera cover, follow the images exactly in reverse: first, lower the outside edge until the two protruding tabs on the cover are slotted securely into the bracket on the outer edge of the camera module. Then, hinge the cover closed.
    • The cover only lays flat after the two tabs are seated correctly.
  28. iPhone 11 Logic Board Replacement, Disconnect the cameras: 28 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the cameras: 28 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Disconnect the cameras: 28 단계, 이미지 3개 중 3개
    • Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  29. iPhone 11 Logic Board Replacement, Loosen the camera assembly: 29 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Loosen the camera assembly: 29 단계, 이미지 2개 중 2개
    • Insert the point of a spudger at the bottom right corner of the camera, between the camera assembly and the iPhone's frame.
    • Gently pry up to lever the camera out of the iPhone.
  30. iPhone 11 Logic Board Replacement: 30 단계, 이미지 1개 중 1개
    • Remove the rear-facing camera assembly.
  31. iPhone 11 Logic Board Replacement, Disconnect the Lightning port flex cable: 31 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the Lightning port flex cable: 31 단계, 이미지 2개 중 2개
    • Use a spudger or a fingernail to pry up and disconnect the flex cable for the Lightning connector assembly.
  32. iPhone 11 Logic Board Replacement, Remove three Phillips screws: 32 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Remove three Phillips screws: 32 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Remove three Phillips screws: 32 단계, 이미지 3개 중 3개
    • Remove the three Phillips screws surrounding the SIM card reader:
    • One 1.5 mm screw
    • One 1.9 mm screw
    • One 1.6 mm screw securing a grounding bracket
    • Removing the grounding bracket secured by the final screw.
  33. iPhone 11 Logic Board Replacement, Remove the standoff screw: 33 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Remove the standoff screw: 33 단계, 이미지 2개 중 2개
    • Use a standoff driver to remove the 3.1 mm screw securing the SIM card reader connector bracket.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage nearby components.
  34. iPhone 11 Logic Board Replacement, Remove the SIM reader's connector bracket: 34 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Remove the SIM reader's connector bracket: 34 단계, 이미지 2개 중 2개
    • Remove the SIM reader's connector bracket.
  35. iPhone 11 Logic Board Replacement, Disconnect the SIM card reader: 35 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the SIM card reader: 35 단계, 이미지 2개 중 2개
    • While gently lifting the Lightning connector flex cable out of the way, use the point of a spudger to pry up and disconnect the SIM card reader flex cable.
  36. iPhone 11 Logic Board Replacement, Push the SIM eject plunger aside: 36 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement, Push the SIM eject plunger aside: 36 단계, 이미지 2개 중 2개
    • Use the point of a spudger to push the SIM eject plunger out towards the edge of the phone.
  37. iPhone 11 Logic Board Replacement, Remove the SIM reader: 37 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Remove the SIM reader: 37 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Remove the SIM reader: 37 단계, 이미지 3개 중 3개
    • Lift the SIM card reader and slide it toward the outside edge of the iPhone.
    • Remove the SIM card reader.
  38. iPhone 11 Logic Board Replacement, Disconnect the front camera assembly: 38 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the front camera assembly: 38 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Disconnect the front camera assembly: 38 단계, 이미지 3개 중 3개
    • Use a spudger or fingernail to disconnect the two front camera cable connectors by prying them from straight up from their sockets.
  39. iPhone 11 Logic Board Replacement, Remove the front camera array: 39 단계, 이미지 1개 중 1개
    • The front camera array houses the FaceID sensor, which is paired to the motherboard. If you use the front camera array that does not belong to its respective board, FaceID will not function. Make sure your logic board comes with its original front camera array if you want to retain FaceID functionality.
    • Remove the front camera assembly.
  40. iPhone 11 Logic Board Replacement, Remove the standoff screws: 40 단계, 이미지 1개 중 1개
    • Remove the two 3.2 mm standoff screws.
  41. iPhone 11 Logic Board Replacement: 41 단계, 이미지 2개 중 1개 iPhone 11 Logic Board Replacement: 41 단계, 이미지 2개 중 2개
    • Remove the upper cable bracket.
  42. iPhone 11 Logic Board Replacement, Disconnect upper cables: 42 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Disconnect upper cables: 42 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Disconnect upper cables: 42 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the cable connectors for the volume, power, and silent switch.
  43. iPhone 11 Logic Board Replacement, Disconnect the charging connectors: 43 단계, 이미지 3개 중 1개 iPhone 11 Logic Board Replacement, Disconnect the charging connectors: 43 단계, 이미지 3개 중 2개 iPhone 11 Logic Board Replacement, Disconnect the charging connectors: 43 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the cable connectors for the lighting port and wireless charging coil.
  44. iPhone 11 Logic Board Replacement: 44 단계, 이미지 1개 중 1개
    • Carefully remove the logic board from the phone chassis.
    • Be careful not to snag the logic board on any cables.
결론
다른 51명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arty
회원 가입일: 10/27/19
31,189 평판
안내서 108개를 작성함
18가이드 댓글
Nice beakdown! Might also use post-processing on stopping point above video view over main pcb to highlight screw location with color coding
26nn - 답글
Thanks for the recommendation, I’ll take this into account in the following videos.
Arty -
where can I buy a logic board for an Iphone 11
Cassie Srubar - 답글
Try AliExpress or eBay
Lawson Glomski -
Top, explications claires. Merci pour votre vidéo.
Manar Maiti - 답글
댓글 쓰기
조회 통계:
지난 24시간: 35
지난 7일: 350
지난 30일: 1,484
전체 시간: 84,268
