주요 콘텐츠로 건너뛰기
iPhone 12 Pro Max SIM Card Reader Replacement
필요한 것
  1. iPhone 12 Pro Max SIM Card Reader Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone 12 Pro Max SIM Card Reader Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 3개
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
  3. iPhone 12 Pro Max SIM Card Reader Replacement, Remove the pentalobe screws: 3 단계, 이미지 1개 중 1개
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  4. iPhone 12 Pro Max SIM Card Reader Replacement, Mark your opening picks: 4 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Mark your opening picks: 4 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Mark your opening picks: 4 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  5. iPhone 12 Pro Max SIM Card Reader Replacement, Tape over any cracks: 5 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Tape over any cracks: 5 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Tape over any cracks: 5 단계, 이미지 3개 중 3개
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  6. iPhone 12 Pro Max SIM Card Reader Replacement, Anti-Clamp instructions: 6 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Anti-Clamp instructions: 6 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Anti-Clamp instructions: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  7. iPhone 12 Pro Max SIM Card Reader Replacement: 7 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement: 7 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  8. iPhone 12 Pro Max SIM Card Reader Replacement: 8 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement: 8 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement: 8 단계, 이미지 3개 중 3개
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  9. iPhone 12 Pro Max SIM Card Reader Replacement, Heat the bottom edge: 9 단계, 이미지 1개 중 1개
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  10. iPhone 12 Pro Max SIM Card Reader Replacement, Apply a suction cup: 10 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Apply a suction cup: 10 단계, 이미지 2개 중 2개
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  11. iPhone 12 Pro Max SIM Card Reader Replacement, Lift the screen slightly: 11 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Lift the screen slightly: 11 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Lift the screen slightly: 11 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick at a steep angle into the gap.
    • Make sure to insert the opening pick under the thick plastic bezel to avoid damaging your screen. You should see a visual gap, and the pick shouldn't catch on anything. If you can't see the gap, you'll need to pull the screen up more.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  12. iPhone 12 Pro Max SIM Card Reader Replacement, Heat the right edge: 12 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Heat the right edge: 12 단계, 이미지 2개 중 2개
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 12 Pro Max SIM Card Reader Replacement: 13 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement: 13 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement: 13 단계, 이미지 3개 중 3개
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  14. iPhone 12 Pro Max SIM Card Reader Replacement, Heat the top edge: 14 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 12 Pro Max SIM Card Reader Replacement, Separate the top adhesive: 15 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Separate the top adhesive: 15 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Separate the top adhesive: 15 단계, 이미지 3개 중 3개
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  16. iPhone 12 Pro Max SIM Card Reader Replacement, Heat the left edge: 16 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Heat the left edge: 16 단계, 이미지 2개 중 2개
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  17. iPhone 12 Pro Max SIM Card Reader Replacement, Screen information: 17 단계, 이미지 1개 중 1개
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  18. iPhone 12 Pro Max SIM Card Reader Replacement, Separate the left adhesive: 18 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Separate the left adhesive: 18 단계, 이미지 2개 중 2개
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  19. iPhone 12 Pro Max SIM Card Reader Replacement, Open the iPhone: 19 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Open the iPhone: 19 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Open the iPhone: 19 단계, 이미지 3개 중 3개
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  20. iPhone 12 Pro Max SIM Card Reader Replacement, Unscrew the battery and display connector cover: 20 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Remove four 1.1 mm-long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  21. iPhone 12 Pro Max SIM Card Reader Replacement, Remove the battery and display connector cover: 21 단계, 이미지 1개 중 1개
    • Remove the battery and display connector cover.
  22. iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the battery: 22 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the battery: 22 단계, 이미지 2개 중 2개
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  23. iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the display cable: 23 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the display cable: 23 단계, 이미지 2개 중 2개
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  24. iPhone 12 Pro Max SIM Card Reader Replacement, Unscrew the front sensor connector cover: 24 단계, 이미지 1개 중 1개
    • Use a Y000 driver to remove the four 1.1 mm-long screws securing the front sensor connector cover.
  25. iPhone 12 Pro Max SIM Card Reader Replacement, Remove the front sensor connector cover: 25 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Remove the front sensor connector cover: 25 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Remove the front sensor connector cover: 25 단계, 이미지 3개 중 3개
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
  26. iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the front sensors: 26 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the front sensors: 26 단계, 이미지 2개 중 2개
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  27. iPhone 12 Pro Max SIM Card Reader Replacement, Remove the display assembly: 27 단계, 이미지 1개 중 1개
  28. iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the charging port cable: 28 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the charging port cable: 28 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry the charging port connector straight up and out of its socket on the logic board.
  29. iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the SIM card reader: 29 단계, 이미지 2개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Disconnect the SIM card reader: 29 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry the SIM card reader cable connector straight up and out of its socket on the logic board.
  30. iPhone 12 Pro Max SIM Card Reader Replacement, Unscrew the SIM card reader: 30 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the SIM card reader.
    • One 3.8 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 1.3 mm Phillips screw
  31. iPhone 12 Pro Max SIM Card Reader Replacement, Remove the SIM card reader: 31 단계, 이미지 3개 중 1개 iPhone 12 Pro Max SIM Card Reader Replacement, Remove the SIM card reader: 31 단계, 이미지 3개 중 2개 iPhone 12 Pro Max SIM Card Reader Replacement, Remove the SIM card reader: 31 단계, 이미지 3개 중 3개
    • Carefully lift the SIM card reader out of its recess. Avoid snagging the SIM card reader cable on any other cables.
    • Before reinstallation, make sure to push the SIM eject plunger into the edge of the phone.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Max Answers community for help.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,114 평판
안내서 416개를 작성함
1가이드 댓글
Is it similar for iPhone 13 Pro max?
Matthew Au - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 80
지난 30일: 196
전체 시간: 12,891
