주요 콘텐츠로 건너뛰기
iPhone 14 charging coil assembly replacement
필요한 것
  1. iPhone 14 charging coil assembly replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 2개
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 charging coil assembly replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 14 charging coil assembly replacement, Tape over any cracks: 3 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Tape over any cracks: 3 단계, 이미지 2개 중 2개
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 charging coil assembly replacement, Heat the bottom edge: 4 단계, 이미지 1개 중 1개
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  5. iPhone 14 charging coil assembly replacement, Insert an opening pick: 5 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Insert an opening pick: 5 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Insert an opening pick: 5 단계, 이미지 3개 중 3개
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  6. iPhone 14 charging coil assembly replacement, Heat the left edge: 6 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  7. iPhone 14 charging coil assembly replacement, Slice the left edge adhesive: 7 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Slice the left edge adhesive: 7 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Slice the left edge adhesive: 7 단계, 이미지 3개 중 3개
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  8. iPhone 14 charging coil assembly replacement, Rear glass information: 8 단계, 이미지 1개 중 1개
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
  9. iPhone 14 charging coil assembly replacement, Heat the right edge: 9 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the volume buttons) for 90 seconds or until the rear glass is slightly too hot to touch.
  10. iPhone 14 charging coil assembly replacement, Slice the right edge adhesive: 10 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Slice the right edge adhesive: 10 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Slice the right edge adhesive: 10 단계, 이미지 3개 중 3개
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  11. iPhone 14 charging coil assembly replacement, Heat the top edge: 11 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  12. iPhone 14 charging coil assembly replacement, Slice the top edge adhesive: 12 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Slice the top edge adhesive: 12 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Slice the top edge adhesive: 12 단계, 이미지 3개 중 3개
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  13. iPhone 14 charging coil assembly replacement: 13 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement: 13 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement: 13 단계, 이미지 3개 중 3개
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  14. iPhone 14 charging coil assembly replacement, Open the iPhone: 14 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Open the iPhone: 14 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Open the iPhone: 14 단계, 이미지 3개 중 3개
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  15. iPhone 14 charging coil assembly replacement, Unfasten the battery connector cover screws: 15 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Unfasten the battery connector cover screws: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  16. iPhone 14 charging coil assembly replacement, Remove the battery connector cover: 16 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Remove the battery connector cover: 16 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Remove the battery connector cover: 16 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  17. iPhone 14 charging coil assembly replacement, Disconnect the battery: 17 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Disconnect the battery: 17 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone 14 charging coil assembly replacement, Unfasten the charging coil connector cover screw: 18 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Unfasten the charging coil connector cover screw: 18 단계, 이미지 2개 중 2개
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  19. iPhone 14 charging coil assembly replacement, Remove the charging coil connector bracket: 19 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Remove the charging coil connector bracket: 19 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to remove the charging coil connector cover.
  20. iPhone 14 charging coil assembly replacement, Disconnect the charging coil: 20 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Disconnect the charging coil: 20 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  21. iPhone 14 charging coil assembly replacement, Remove the rear glass assembly: 21 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Remove the rear glass assembly: 21 단계, 이미지 2개 중 2개
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
  22. iPhone 14 charging coil assembly replacement, Cleaning and preparation: 22 단계, 이미지 1개 중 1개
    • Start by removing any adhesive and pieces of glass from your iPhone frame.
    • The adhesive is very sticky so the method that worked for me best was using a razor and a pair of tweezers.
    • Take your time with this. All remaining glass and adhesive left will increase the chance of the backglass breaking again.
  23. iPhone 14 charging coil assembly replacement, Flash clip removal: 23 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Flash clip removal: 23 단계, 이미지 2개 중 2개
    • Unscrew the Y000 screw holding the flash clip into place.
    • Lift the clip up and store it somewhere safe along with the screws and other parts.
  24. iPhone 14 charging coil assembly replacement, Microphone clip removal: 24 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Microphone clip removal: 24 단계, 이미지 2개 중 2개
    • Remove the clip keeping the microphone in place.
    • To do so use a pair of tweezers and slide them under the openings to the side. Just be careful doing so.
    • When done you can see the small cushion between the clip and microphone.
  25. iPhone 14 charging coil assembly replacement, Microphone grill transfer: 25 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Microphone grill transfer: 25 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Microphone grill transfer: 25 단계, 이미지 3개 중 3개
    • You will have to move the microphone grill across to the new backcover before moving on. I had to use heaps of hot air and pry it from the old backcover.
    • Make sure you get the clip holder and the cylindrical grill.
    • You will need some adhesive to glue them back to the new cover. Apply enough the make it stick.
  26. iPhone 14 charging coil assembly replacement, Lift up ribbon cables: 26 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Lift up ribbon cables: 26 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Lift up ribbon cables: 26 단계, 이미지 3개 중 3개
    • Use a hair dryer or a heat gun to apply heat to the backcover.
    • Lift up the ribbon cables carefully with a spudger or flat tweezers as shown in the image.
    • The flash can be pushed inwards from the back when the holding clip has been removed.
  27. iPhone 14 charging coil assembly replacement, Remove charging coil: 27 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Remove charging coil: 27 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Remove charging coil: 27 단계, 이미지 3개 중 3개
    • Use heat from the back and directly to the charging coil to loosen the adhesive of the charging coil.
    • You can use a razor blade to lift up the adhesive flaps on the side. When you are really careful you should be able to do so without damage.
    • Apply heat to the coil again and you may insert flat tweezers between backcover and the coil. It is probably safer to insert it from the bottom part!
  28. iPhone 14 charging coil assembly replacement, Inspect charging coil and magnets: 28 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, Inspect charging coil and magnets: 28 단계, 이미지 2개 중 2개
    • Inspect the coil to make sure there is no damage to the copper and connections.
    • If your new backcover lacks the magnets you have to move them across from old to new in order to move on!
  29. iPhone 14 charging coil assembly replacement, Transfer to new backcover: 29 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Transfer to new backcover: 29 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Transfer to new backcover: 29 단계, 이미지 3개 중 3개
    • Place the old assembly on the new backcover and align everything carefully. You probably won't need new adhesive as the old one is probably still strong enough.
    • Place the flash and microphone back into place, screw down the flash clip and add the clip for the microphone.
  30. iPhone 14 charging coil assembly replacement, First test: 30 단계, 이미지 2개 중 1개 iPhone 14 charging coil assembly replacement, First test: 30 단계, 이미지 2개 중 2개
    • It is always recommended to test anything before resealing the backcover. Rest the new backglass against an object and reseat the coil and then the battery connector.
    • Close the backcover and start up your iPhone. Mine fortunately worked right away.
    • Test the video camera with sound as well as the wireless charging capabilities. If anything seems to be off you can inspect everything again before finalizing this repair.
  31. iPhone 14 charging coil assembly replacement, Camera glass inspection and glue: 31 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Camera glass inspection and glue: 31 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Camera glass inspection and glue: 31 단계, 이미지 3개 중 3개
    • As you can see the camera glass is protected with a red film from the inside. Do not use hard objects to remove it as you could scratch the glass.
    • Use cotton swabs or something similar to clean your camera lenses as well as the camera glass. If you forget this step your photos and videos might look off.
    • Reapply glue to the frame again before closing everything down. My battery came with an adhesive gasket that I used.
  32. iPhone 14 charging coil assembly replacement, Finish: 32 단계, 이미지 3개 중 1개 iPhone 14 charging coil assembly replacement, Finish: 32 단계, 이미지 3개 중 2개 iPhone 14 charging coil assembly replacement, Finish: 32 단계, 이미지 3개 중 3개
    • With everything nice and clean and glue or a gasket added you may reconnect the coil and battery in this order and close the backcover.
    • Start up your iPhone and test everything again to make sure the repair is successful.
    • Screw the two P2 pentalobe screws back to the bottom of your iPhone. You're done!
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Fred
3,822 평판
안내서 13개를 작성함
2가이드 댓글
спасибо большое было все понятно !
Sergey Gridnev - 답글
Thanks for the tutorial! I managed to do this just using my skills for changing batteries, so it’s possible for non-technical people!
Tips:
1. The microphone can be easily removed, but the issue lies with the metal part glued to the back cover. Apply significant heat and carefully remove it only from the back. Avoid attempting to push the microphone from the outside, as the metal mesh is fragile.
2. There are two coils for wireless charging: a larger one and a smaller one, approximately 1mm wide. Be cautious, especially near the top where coils meet the cable
Thomas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 21
지난 7일: 162
지난 30일: 650
전체 시간: 9,109
