주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 15 Pro Max Taptic Engine Replacement
필요한 것
    1. iPhone 15 Pro Max Taptic Engine Replacement, Prepare your phone for disassembly: 1 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Prepare your phone for disassembly: 1 단계, 이미지 2개 중 2개
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      댓글 쓰기
    2. iPhone 15 Pro Max Taptic Engine Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 2개
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      댓글 쓰기
    1. iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 3개
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      댓글 쓰기
    1. iPhone 15 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: 4 단계, 이미지 1개 중 1개
      • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
      댓글 쓰기
    1. iPhone 15 Pro Max Taptic Engine Replacement, Heat the bottom edge: 5 단계, 이미지 1개 중 1개
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      댓글 쓰기
    2. iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 3개
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      댓글 쓰기
    3. iPhone 15 Pro Max Taptic Engine Replacement, Screen information: 7 단계, 이미지 1개 중 1개
      • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
      • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
      댓글 쓰기
    4. iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 3개
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      댓글 쓰기
    5. iPhone 15 Pro Max Taptic Engine Replacement, Heat the right edge: 9 단계, 이미지 1개 중 1개
      • Heat the right edge of the screen until it's hot to the touch.
      댓글 쓰기
    6. iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: 10 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: 10 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: 10 단계, 이미지 3개 중 3개
      • Don't insert your pick deeper than 5 mm along the right edge.
      • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
      • Rotate your pick so the flat edge is under the screen.
      댓글 쓰기
    7. iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: 11 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: 11 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: 11 단계, 이미지 3개 중 3개
      • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
      • Insert a second opening pick to the right of the first pick.
      댓글 쓰기
    8. iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: 12 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: 12 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: 12 단계, 이미지 3개 중 3개
      • Slide the first pick back to the bottom right corner of the screen.
      • Slide the second pick to the top right corner of the screen to separate the adhesive.
      • Leave these picks inserted to prevent the adhesive from resealing.
      댓글 쓰기
    9. iPhone 15 Pro Max Taptic Engine Replacement, Heat the top edge: 13 단계, 이미지 1개 중 1개
      • Heat the top edge of the screen until it's hot to the touch.
      댓글 쓰기
    10. iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: 14 단계, 이미지 3개 중 3개
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
      댓글 쓰기
    11. iPhone 15 Pro Max Taptic Engine Replacement, Heat the left edge: 15 단계, 이미지 1개 중 1개
      • Heat the left edge of the screen until it's hot to the touch.
      댓글 쓰기
    12. iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: 16 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: 16 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: 16 단계, 이미지 3개 중 3개
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      댓글 쓰기
    1. iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: 17 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: 17 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: 17 단계, 이미지 3개 중 3개
      • Gently swing open the screen to the left of the phone.
      • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the screen against a box or similar object so it doesn't strain the cables.
      댓글 쓰기
    2. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the logic board cover: 18 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the logic board cover: 18 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      FixMat
      $36.95
      • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
      • One 2.1 mm‑long screw
      • Five 1.5 mm‑long screws
      댓글 쓰기
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: 19 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: 19 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: 19 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
      • Remove the cover.
      댓글 쓰기
    4. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: 20 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: 20 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: 20 단계, 이미지 3개 중 3개
      • Use the tip of an opening pick to pry up and disconnect the battery press connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      댓글 쓰기
    1. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the ambient light sensor: 21 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the ambient light sensor: 21 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
      댓글 쓰기
    2. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the screen: 22 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the screen: 22 단계, 이미지 2개 중 2개
      • Disconnect the screen press connector.
      댓글 쓰기
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the screen: 23 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the screen: 23 단계, 이미지 2개 중 2개
      • Remove the screen.
      • During reassembly, stop here and use this guide to install new screen adhesive.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      댓글 쓰기
    1. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the loudspeaker: 24 단계, 이미지 1개 중 1개
      • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
      • Three 2.1 mm screws
      • One 2.9 mm screw
      댓글 쓰기
    2. iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: 25 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: 25 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: 25 단계, 이미지 3개 중 3개
      • A piece of tape connects the top edges of the Taptic Engine and loudspeaker.
      • Insert an opening pick under the tape in the small gap between the Taptic Engine and the loudspeaker.
      • Slide the pick toward the left edge of the phone to separate the tape from the Taptic Engine.
      댓글 쓰기
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: 26 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: 26 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: 26 단계, 이미지 3개 중 3개
      • Insert the flat end of a spudger between the right edge of the loudspeaker and the frame.
      • Pry up until you can grab the loudspeaker with your fingers.
      • Remove the loudspeaker.
      댓글 쓰기
    1. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: 27 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: 27 단계, 이미지 2개 중 2개
      • Use the tip of your spudger to pry up and disconnect the Taptic Engine press connector.
      댓글 쓰기
    2. iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: 28 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: 28 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: 28 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove the two screws securing the grounding clip:
      • One 1.2 mm Phillips #000 screw
      • One 1.9 mm tri-point Y000 screw
      • Use tweezers to remove the grounding clip.
      댓글 쓰기
    3. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the Taptic Engine: 29 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Standoff Screwdriver for iPhones
      $5.49
      • Remove the two screws securing the Taptic Engine:
      • One 2.9 mm Phillips #000 screw
      • One 3.8 mm standoff screw
      • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
      댓글 쓰기
    4. iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: 30 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: 30 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: 30 단계, 이미지 3개 중 3개
      • Insert the flat end of a spudger between the left edge of the Taptic Engine and the frame.
      • Pry up until you can grab the Taptic Engine with your fingers.
      • Remove the Taptic Engine.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
105,740 평판
안내서 472개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 30,038개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 90
지난 30일: 335
전체 시간: 7,969
