주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 4S Upper Antenna Replacement
필요한 것
  1. iPhone 4S Upper Antenna Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
    • Be sure the driver is well-seated when removing Pentalobe screws—they are easy to strip.
    댓글 쓰기
  2. iPhone 4S Upper Antenna Replacement: 2 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 2 단계, 이미지 2개 중 2개
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
    댓글 쓰기
  3. iPhone 4S Upper Antenna Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
    • Remove the rear panel from the iPhone.
    댓글 쓰기
  4. iPhone 4S Upper Antenna Replacement, Battery: 4 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the following screws securing the battery connector to the logic board:
    • One 1.7 mm Phillips screw (PH00)
    • One 1.5 mm Phillips screw (PH00)
    댓글 쓰기
  5. iPhone 4S Upper Antenna Replacement: 5 단계, 이미지 3개 중 1개 iPhone 4S Upper Antenna Replacement: 5 단계, 이미지 3개 중 2개 iPhone 4S Upper Antenna Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully push the pressure contact away from the battery connector until it slides free from its position.
    • Remove the pressure contact.
    댓글 쓰기
  6. iPhone 4S Upper Antenna Replacement: 6 단계, 이미지 3개 중 1개 iPhone 4S Upper Antenna Replacement: 6 단계, 이미지 3개 중 2개 iPhone 4S Upper Antenna Replacement: 6 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board.
    • Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first.
    • The battery connector comes off vertically from the logic board. Do not apply force sideways.
    • Be careful not to pry at the battery connector socket itself, or it may detach from the logic board. There are four very small solder points awaiting this mistake!
    댓글 쓰기
  7. iPhone 4S Upper Antenna Replacement, Reassembly tip: 7 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement, Reassembly tip: 7 단계, 이미지 2개 중 2개
    • During reassembly, be sure to carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
    • Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    댓글 쓰기
  8. iPhone 4S Upper Antenna Replacement: 8 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 8 단계, 이미지 2개 중 2개
    • Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
    • Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
    • If the adhesive is too strong, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a plastic opening tool to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    댓글 쓰기
  9. iPhone 4S Upper Antenna Replacement: 9 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 9 단계, 이미지 2개 중 2개
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • Be careful not to pull the plastic pull tab too hard as it can be ripped off very easily.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the ribbon cable.
    • If your replacement battery came with an uncreased cable, carefully crease the cable into the proper shape before installing the battery into the phone.
    • While installing the replacement battery, temporarily connect the battery connector to the phone to ensure proper alignment. Once the battery is glued in place, disconnect the battery connector.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
    댓글 쓰기
  10. iPhone 4S Upper Antenna Replacement, Dock Connector Cable: 10 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement, Dock Connector Cable: 10 단계, 이미지 2개 중 2개
    • Remove the following screws securing the dock connector cable cover to the logic board:
    • One 1.2 mm Phillips screw
    • Remove the metal dock connector cable cover.
    댓글 쓰기
  11. iPhone 4S Upper Antenna Replacement: 11 단계, 이미지 1개 중 1개
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
    댓글 쓰기
  12. iPhone 4S Upper Antenna Replacement: 12 단계, 이미지 1개 중 1개
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
    댓글 쓰기
  13. iPhone 4S Upper Antenna Replacement: 13 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 13 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
    댓글 쓰기
  14. iPhone 4S Upper Antenna Replacement, Rear Camera: 14 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Be wary of the outer plastic ring located on top of the rear camera's flash assembly. It can be easily displaced if not removed during disassembly.
    • You can use tweezers, a plastic opening tool, or a spudger to remove the outer plastic ring.
    댓글 쓰기
  15. iPhone 4S Upper Antenna Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the following four screws securing the cable cover to the logic board:
    • One 2.7 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 1.3 mm Phillips screw
    댓글 쓰기
  16. iPhone 4S Upper Antenna Replacement: 16 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 16 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
    • Lift the cable cover from its edge nearest the top and remove it from the iPhone.
    댓글 쓰기
  17. iPhone 4S Upper Antenna Replacement: 17 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 17 단계, 이미지 2개 중 2개
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • There is a small rubber gasket that sits underneath the rear-facing camera. Make sure that it is properly seated before reassembly.
    댓글 쓰기
  18. iPhone 4S Upper Antenna Replacement, SIM Card: 18 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement, SIM Card: 18 단계, 이미지 2개 중 2개
    • Use a SIM eject tool or a paperclip to eject the SIM and its tray.
    • This may require a significant amount of force.
    • Remove the SIM and its tray.
    댓글 쓰기
  19. iPhone 4S Upper Antenna Replacement, Logic Board: 19 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement, Logic Board: 19 단계, 이미지 2개 중 2개
    • Remove the five cables near the top of the logic board in the following order:
    • Headphone jack/volume button cable
    • Front facing camera cable
    • Digitizer cable
    • Display data cable
    • Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
    • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
    • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
    댓글 쓰기
  20. iPhone 4S Upper Antenna Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the 1.5 mm Phillips screw securing the grounding clip to the logic board near the headphone jack.
    댓글 쓰기
  21. iPhone 4S Upper Antenna Replacement: 21 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 21 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry the small grounding clip up off the logic board.
    • Carefully grasp the grounding clip and remove it from the iPhone.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the grounding clip (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    댓글 쓰기
  22. iPhone 4S Upper Antenna Replacement: 22 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    댓글 쓰기
  23. iPhone 4S Upper Antenna Replacement: 23 단계, 이미지 1개 중 1개
    • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna from the logic board.
    댓글 쓰기
  24. iPhone 4S Upper Antenna Replacement: 24 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 24 단계, 이미지 2개 중 2개
    • If present, peel the piece of black tape covering the hidden screw near the power button.
    • Remove the 2.6 mm Phillips screw securing the logic board near the power button.
    • (Use caution when removing this screw and removing the power contact held by it; the contact tab will come loose with the screw)
    • Notice the small rubber bumper under the screen & digitizer cables (which are detached at top above the Q-code). This bumper can fall off of the logic board when removed or get stuck to the cables and fall off later.
    댓글 쓰기
  25. iPhone 4S Upper Antenna Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the following screws securing the logic board to the case:
    • One 2.5 mm Phillips screw near the vibrator motor
    • One 2.4 mm Phillips screw
    • One 3.6 mm standoff along the side of the logic board nearest the battery opening.
    • Use a standoff driver bit and driver handle to remove the single 3.6 mm standoff screw.
    댓글 쓰기
  26. iPhone 4S Upper Antenna Replacement: 26 단계, 이미지 1개 중 1개
    • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
    • Remove the logic board.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    • There is a small rubber bumper that sits on the top edge of the logic board where the digitizer and screen cables come through the case. It protects the cables as they bend over the top of the logic board. This can either get stuck to the cables or fall off the logic board when it comes out. Look back over step 22 for more details.
    댓글 쓰기
  27. iPhone 4S Upper Antenna Replacement: 27 단계, 이미지 1개 중 1개
    • Be sure not to lose the small grounding finger for the rear facing camera near the power button. This finger rests on top of the PCB, screwed down, and covered with the adhesive black plastic tape.
    댓글 쓰기
  28. iPhone 4S Upper Antenna Replacement, Upper Antenna: 28 단계, 이미지 1개 중 1개
    • Remove the 2.4 mm Phillips screw next to the headphone jack.
    댓글 쓰기
  29. iPhone 4S Upper Antenna Replacement: 29 단계, 이미지 2개 중 1개 iPhone 4S Upper Antenna Replacement: 29 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the edge of a plastic opening tool to peel the upper antenna off the headphone jack.
    • Use a pair of tweezers to remove the upper antenna from the iPhone.
    • Before reassembly, be sure to clean the metal-to-metal contact point on the upper antenna (not the mating halves of its connector) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 88명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Walter Galan
710,269 평판
안내서 1,203개를 작성함
14가이드 댓글
the upper antenna is the wifi antena?? or the thing by the speakers is the wifi antenna? i am a bit confused!
Jigar - 답글 공유
where can u buy this piece, Ive been searching for about an hour now, a friend of mine tried to fix their phone and ripped this piece off... no idea how... any help?
willsrepairs - 답글 공유
The guide is very good and I succeeded in opening the iphone and fixing back again all the parts. Unfortunately, the wi-fi module still doesn't work, I don't know why. Anyway, many thanks to all ifixit staff, since they are helpful, efficient and kind. Alberto from Italy
abragaglia62 - 답글 공유
Just completed replacing the battery and the wifi antenna. Went swimmingly. Thanks for the great directions. You guys rock! This fixed my 4s wifi grayed out issue. One thing to note, they wifi antenna needs to click into the socket to get a good connection. Put it together without checking this the first time and, no go.... Opened it up and made sure the connection was good and wahlah... AWSOME!
kempilt - 답글 공유
Hello, I had the issue with the grayed out wifi button. I replaced the upper antenna and the cellular antenna. When I turned on the phone the wifi was still greyed out. Does anyone has any other suggestions how I could possibly fix it.
Thanks
marcodegaetano - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 83
전체 시간: 209,605
