주요 콘텐츠로 건너뛰기
iPhone 7 Front Camera and Sensor Cable Replacement
필요한 것
동영상 개요
  1. iPhone 7 Front Camera and Sensor Cable Replacement, Pentalobe Screws: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Front Camera and Sensor Cable Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 7 Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Front Camera and Sensor Cable Replacement: 4 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 4 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Front Camera and Sensor Cable Replacement: 5 단계, 이미지 2개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Front Camera and Sensor Cable Replacement, Heat the display: 6 단계, 이미지 1개 중 1개
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 7 Front Camera and Sensor Cable Replacement, Separate the display: 7 단계, 이미지 2개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement, Separate the display: 7 단계, 이미지 2개 중 2개
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 7 Front Camera and Sensor Cable Replacement: 8 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 8 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 8 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 7 Front Camera and Sensor Cable Replacement: 9 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 9 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 9 단계, 이미지 3개 중 3개
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. iPhone 7 Front Camera and Sensor Cable Replacement, Screen information: 10 단계, 이미지 1개 중 1개
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 7 Front Camera and Sensor Cable Replacement: 11 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 11 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 11 단계, 이미지 3개 중 3개
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 7 Front Camera and Sensor Cable Replacement: 12 단계, 이미지 2개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 12 단계, 이미지 2개 중 2개
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Front Camera and Sensor Cable Replacement: 13 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 13 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 13 단계, 이미지 3개 중 3개
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  14. iPhone 7 Front Camera and Sensor Cable Replacement: 14 단계, 이미지 2개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 14 단계, 이미지 2개 중 2개
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  15. iPhone 7 Front Camera and Sensor Cable Replacement: 15 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 15 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 15 단계, 이미지 3개 중 3개
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone 7 Front Camera and Sensor Cable Replacement, Battery Disconnection: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tri-point Y000 Screwdriver
    $5.99
  17. iPhone 7 Front Camera and Sensor Cable Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the lower connector bracket.
  18. iPhone 7 Front Camera and Sensor Cable Replacement: 18 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 18 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 18 단계, 이미지 3개 중 3개
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  19. iPhone 7 Front Camera and Sensor Cable Replacement, Display Assembly: 19 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement, Display Assembly: 19 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement, Display Assembly: 19 단계, 이미지 3개 중 3개
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  20. iPhone 7 Front Camera and Sensor Cable Replacement: 20 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 20 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  21. iPhone 7 Front Camera and Sensor Cable Replacement: 21 단계, 이미지 2개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 21 단계, 이미지 2개 중 2개
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  22. iPhone 7 Front Camera and Sensor Cable Replacement: 22 단계, 이미지 1개 중 1개
  23. iPhone 7 Front Camera and Sensor Cable Replacement, Earpiece Speaker: 23 단계, 이미지 1개 중 1개
    • Remove the three Phillips screws securing the earpiece bracket to the front panel:
    • Two 2.6 mm screws
    • One 1.7 mm screw
  24. iPhone 7 Front Camera and Sensor Cable Replacement: 24 단계, 이미지 1개 중 1개
    • Remove the earpiece speaker bracket.
  25. iPhone 7 Front Camera and Sensor Cable Replacement: 25 단계, 이미지 2개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 25 단계, 이미지 2개 중 2개
    • Lift the front facing camera out of the way to access the earpiece speaker.
  26. iPhone 7 Front Camera and Sensor Cable Replacement: 26 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws securing the earpiece speaker to the front panel:
    • One 1.9 mm screw
    • One 2.5 mm screw
  27. iPhone 7 Front Camera and Sensor Cable Replacement: 27 단계, 이미지 1개 중 1개
    • Remove the earpiece speaker.
  28. iPhone 7 Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: 28 단계, 이미지 1개 중 1개
    • Reheat your iOpener and apply it to the upper edge of the display assembly to soften the adhesive holding the front camera and sensor assembly in place.
    • Wait about two minutes before moving on to the next step to adequately soften the adhesive.
  29. iPhone 7 Front Camera and Sensor Cable Replacement: 29 단계, 이미지 2개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 29 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry the ambient light sensor out of its recess on the front panel.
    • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
  30. iPhone 7 Front Camera and Sensor Cable Replacement: 30 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 30 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 30 단계, 이미지 3개 중 3개
    • Slide the pick towards the front facing camera housing, separating the adhesive holding the cable to the front panel. Stop just before the screw posts.
  31. iPhone 7 Front Camera and Sensor Cable Replacement: 31 단계, 이미지 3개 중 1개 iPhone 7 Front Camera and Sensor Cable Replacement: 31 단계, 이미지 3개 중 2개 iPhone 7 Front Camera and Sensor Cable Replacement: 31 단계, 이미지 3개 중 3개
    • Use the pick to lift the camera cable up off of the two plastic posts on the front panel and separate it from the last of the adhesive.
  32. iPhone 7 Front Camera and Sensor Cable Replacement: 32 단계, 이미지 1개 중 1개
    • Remove the front camera and sensor cable.
결론
다른 166명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Evan Noronha
회원 가입일: 02/05/15
228,189 평판
안내서 168개를 작성함
20가이드 댓글
Question ..... I have a clear square plastic piece (open in the center) with a tab on one side. What is that for?
Mike McCleery - 답글
Holds the lens in place.
Edward L Johnson III -
No that is for the ambient light sensor. LCD replacements come with it already installed on em’, so you can toss it if you see it on the replacement already. The larger, circular plastic piece is for the lens.
Brandon Neves -
Does the iPhone 7 plus Front Camera and Sensor Cable Replacement has to do anything with the earpieces speaker? i have replace my iphone 7 plus screen and front camera and sensor cable replacement and speaker and it still doesn’t work. what could really be wrong with my iphone 7 plus?
Saleka Chang - 답글
Awesome tutorial, thank you! I couldn’t have replaced my camera without this! Well I could have but not the right way!!
Cynthia Hollingsworth - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 108
지난 30일: 637
전체 시간: 177,847
