주요 콘텐츠로 건너뛰기
iPhone X Rear-Facing Cameras Replacement
필요한 것
  1. iPhone X Rear-Facing Cameras Replacement, Pentalobe Screws: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • If the screws are stripped or damaged, replace the screws.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone X Rear-Facing Cameras Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone X Rear-Facing Cameras Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 3개
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone X Rear-Facing Cameras Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone X Rear-Facing Cameras Replacement: 5 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 5 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone X Rear-Facing Cameras Replacement: 6 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 6 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 6 단계, 이미지 3개 중 3개
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone X Rear-Facing Cameras Replacement: 7 단계, 이미지 1개 중 1개
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
    • If you use a hairdryer or heat gun, do not heat to much because that can result in damaging the screen.
  8. iPhone X Rear-Facing Cameras Replacement: 8 단계, 이미지 2개 중 1개 iPhone X Rear-Facing Cameras Replacement: 8 단계, 이미지 2개 중 2개
    • If using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone X Rear-Facing Cameras Replacement: 9 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 9 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 9 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel, not the screen itself.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone X Rear-Facing Cameras Replacement: 10 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 10 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 10 단계, 이미지 3개 중 3개
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone X Rear-Facing Cameras Replacement, Screen information: 11 단계, 이미지 1개 중 1개
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone X Rear-Facing Cameras Replacement: 12 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 12 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 12 단계, 이미지 3개 중 3개
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone X Rear-Facing Cameras Replacement: 13 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 13 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 13 단계, 이미지 3개 중 3개
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  14. iPhone X Rear-Facing Cameras Replacement: 14 단계, 이미지 1개 중 1개
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone X Rear-Facing Cameras Replacement: 15 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 15 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 15 단계, 이미지 3개 중 3개
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • As pictured, make sure the frame comes off with display and doesn't get stuck in the device.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  16. iPhone X Rear-Facing Cameras Replacement, Display Assembly: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Remove five Y000 screws securing the logic board connector bracket, of the following lengths:
    • Three 1.1 mm screws
    • One 3.1 mm screw
    • One 3.7 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  17. iPhone X Rear-Facing Cameras Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone X Rear-Facing Cameras Replacement: 18 단계, 이미지 2개 중 1개 iPhone X Rear-Facing Cameras Replacement: 18 단계, 이미지 2개 중 2개
    • Use the point of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  19. iPhone X Rear-Facing Cameras Replacement: 19 단계, 이미지 2개 중 1개 iPhone X Rear-Facing Cameras Replacement: 19 단계, 이미지 2개 중 2개
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  20. iPhone X Rear-Facing Cameras Replacement: 20 단계, 이미지 2개 중 1개 iPhone X Rear-Facing Cameras Replacement: 20 단계, 이미지 2개 중 2개
    • Use the point of a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone X Rear-Facing Cameras Replacement: 21 단계, 이미지 2개 중 1개 iPhone X Rear-Facing Cameras Replacement: 21 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  22. iPhone X Rear-Facing Cameras Replacement: 22 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 22 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 22 단계, 이미지 3개 중 3개
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  23. iPhone X Rear-Facing Cameras Replacement: 23 단계, 이미지 1개 중 1개
  24. iPhone X Rear-Facing Cameras Replacement, Rear-Facing Cameras: 24 단계, 이미지 1개 중 1개
    • Remove two Phillips screws securing the camera bracket, of the following lengths:
    • One 2.3 mm screw
    • One 2.0 mm screw
  25. iPhone X Rear-Facing Cameras Replacement: 25 단계, 이미지 2개 중 1개 iPhone X Rear-Facing Cameras Replacement: 25 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to gently fold the small metal grounding bracket out of the way. Do not pull up on it as it is connected to a fragile flex cable.
  26. iPhone X Rear-Facing Cameras Replacement: 26 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 26 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 26 단계, 이미지 3개 중 3개
    • Lift the camera bracket from the edge closest to the battery, and remove it.
    • To reinstall the camera bracket, follow the images exactly in reverse: first, lower the outside edge until the tab on the right side slots into the gap between the phone's case and the camera module. Then, hinge the bracket down over the camera module.
  27. iPhone X Rear-Facing Cameras Replacement: 27 단계, 이미지 3개 중 1개 iPhone X Rear-Facing Cameras Replacement: 27 단계, 이미지 3개 중 2개 iPhone X Rear-Facing Cameras Replacement: 27 단계, 이미지 3개 중 3개
    • Use an opening tool or fingernail to disconnect the two camera connectors by prying them straight up from their sockets.
  28. iPhone X Rear-Facing Cameras Replacement: 28 단계, 이미지 2개 중 1개 iPhone X Rear-Facing Cameras Replacement: 28 단계, 이미지 2개 중 2개
    • Press the point of a spudger against a small notch on the bottom right corner of the camera module.
    • Gently pry up to lever the camera out of the iPhone.
  29. iPhone X Rear-Facing Cameras Replacement: 29 단계, 이미지 1개 중 1개
    • Remove the rear-facing camera module.
결론
다른 47명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,114 평판
안내서 416개를 작성함
2가이드 댓글
So in step 21 the grounding plate that sits on top of the bracket… which flex is that attached to? This X i’m working on was used for navigation on a motorcycle trip by my client and from that point on the rear came image was vibrating. I noticed this flex is torn but can’t identify the flex it came detached from. Hope someone knows so I don’t need to pull it apart to find out before gettinf the right parts in?! Many thanks in advance
Manus - 답글
It’s bluetooth antena flex
Koriakinides -
댓글 쓰기
조회 통계:
지난 24시간: 110
지난 7일: 564
지난 30일: 1,337
전체 시간: 72,280
