주요 콘텐츠로 건너뛰기
iPod Shuffle 4th Generation Rear Panel Replacement
Walter Galan
Walter Galan3 다른 기여자
최종 수정일 October 8, 2024
예상시간 없음
어려움
Remove the rear panel to access the internals of your Shuffle.
필요한 것
도구
  1. iPod Shuffle 4th Generation Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
  2. iPod Shuffle 4th Generation Rear Panel Replacement: 2 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Rear Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
  3. iPod Shuffle 4th Generation Rear Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the rear panel from the Shuffle.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Galan
701,259 평판
안내서 1,203개를 작성함
댓글 2개
what glue to fix it?
pedro_bizarro - 답글
I recommend 2mm TESA tape
Ben Capehart -
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 35
지난 30일: 65
전체 시간: 9,750
