주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iView-776TPCII Digitizer Replacement
필요한 것
    1. iView-776TPCII Digitizer Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 iView-776TPCII Digitizer Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 iView-776TPCII Digitizer Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      댓글 쓰기
    2. iView-776TPCII Digitizer Replacement: 2 단계, 이미지 2개 중 1개 iView-776TPCII Digitizer Replacement: 2 단계, 이미지 2개 중 2개
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      댓글 쓰기
    1. iView-776TPCII Digitizer Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
      • Do this all around the battery until it comes off.
      • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
      • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
      댓글 쓰기
    2. iView-776TPCII Digitizer Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
      • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
      • Once heated, use tweezers to pull the wires free from their connections.
      • To ease reassembly, take note of which wire went to the positive and negative terminals.
      댓글 쓰기
    1. iView-776TPCII Digitizer Replacement, Wi-Fi Antenna: 5 단계, 이미지 2개 중 1개 iView-776TPCII Digitizer Replacement, Wi-Fi Antenna: 5 단계, 이미지 2개 중 2개
      • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
      댓글 쓰기
    2. iView-776TPCII Digitizer Replacement: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
      • Once heated, use tweezers to pull the wire free from its connection.
      댓글 쓰기
    1. iView-776TPCII Digitizer Replacement, Camera Assembly: 7 단계, 이미지 2개 중 1개 iView-776TPCII Digitizer Replacement, Camera Assembly: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Heavy-Duty Spudger
      • The camera module is located in the upper-right corner of the tablet.
      • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
      • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
      • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
      댓글 쓰기
    2. iView-776TPCII Digitizer Replacement: 8 단계, 이미지 2개 중 1개 iView-776TPCII Digitizer Replacement: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
      • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
      • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
      댓글 쓰기
    3. iView-776TPCII Digitizer Replacement: 9 단계, 이미지 1개 중 1개
      • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
      댓글 쓰기
    1. iView-776TPCII Digitizer Replacement, Motherboard: 10 단계, 이미지 3개 중 1개 iView-776TPCII Digitizer Replacement, Motherboard: 10 단계, 이미지 3개 중 2개 iView-776TPCII Digitizer Replacement, Motherboard: 10 단계, 이미지 3개 중 3개
      • Remove the three 2.2mm Phillips head screws using a screwdriver to loosen the motherboard from the shell.
      • Check "Screwdriver Best Practices" as needed for help on how to properly use a screwdriver with your device.
      댓글 쓰기
    2. iView-776TPCII Digitizer Replacement: 11 단계, 이미지 2개 중 1개 iView-776TPCII Digitizer Replacement: 11 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the 45 degree tweezers to lift the black section of the digitizer ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • When reassembling the device, be sure to fully secure the ribbon cable back into the ZIF adapter.
      댓글 쓰기
    3. iView-776TPCII Digitizer Replacement: 12 단계, 이미지 3개 중 1개 iView-776TPCII Digitizer Replacement: 12 단계, 이미지 3개 중 2개 iView-776TPCII Digitizer Replacement: 12 단계, 이미지 3개 중 3개
      • Use the 45 degree tweezers to lift the black section of the LCD ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • The motherboard is now separated from the digitizer and front panel and can be safely removed from the device.
      댓글 쓰기
    1. iView-776TPCII Digitizer Replacement, Digitizer: 13 단계, 이미지 3개 중 1개 iView-776TPCII Digitizer Replacement, Digitizer: 13 단계, 이미지 3개 중 2개 iView-776TPCII Digitizer Replacement, Digitizer: 13 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool between the digitizer and the screen. Use a prying motion to loosen the digitizer from its plastic case.
      • If you find it hard to separate the two components at first, try to use another plastic opening tool for support.
      • Continue moving along the edge of the digitizer until it is fully separated.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Cory Gratzer
회원 가입일: 09/16/15
586 평판
안내서 5개를 작성함
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S2G2
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 31
전체 시간: 994
