주요 콘텐츠로 건너뛰기
Xbox One Power Brick (Day One Edition) Disassembly
2 단계
Xbox One Power Brick (Day One Edition) Disassembly, Disconnect Fan Cable: 0 단계, 이미지 2개 중 1개 Xbox One Power Brick (Day One Edition) Disassembly, Disconnect Fan Cable: 0 단계, 이미지 2개 중 2개
  • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
  • Using the point end of your plastic spudger, or your fingers, gently pull back the tab holding the fan power cord in place.
  • Gently pull the cable up and away from the circuit board.
  • If you look inside the yellow box, top left corner, you will notice a grey color on top of a capacitor. I'm not positive what this substance is but it has a consistency of sticky tack, if you remember playing with that as a kid. When I first opened the power supply the fan power cable was pressed into it rendering it stuck. Gently pull the cable up
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
