주요 콘텐츠로 건너뛰기
Apple AirPort Express Base Station Power Supply Kit
30 단계
Apple AirPort Express Base Station Power Supply Kit: 0 단계, 이미지 3개 중 1개 Apple AirPort Express Base Station Power Supply Kit: 0 단계, 이미지 3개 중 2개 Apple AirPort Express Base Station Power Supply Kit: 0 단계, 이미지 3개 중 3개
  • Secure the PCB to the upper case half using the original 5.38 mm #1 Phillips screw and the included washer.
  • Do not over-tighten the screw or you will break the screw hole.
  • Be sure to orient the PCB so that the voltage regulator points towards where the grey power inlet used to be.
  • Peel the white back off the thermal pad, being careful not to accidentally peel the thermal pad off of the heat sink.
  • Set the heat sink onto the voltage regulator so that their lower left corners, as oriented in the third picture, are aligned. Press the heat sink firmly onto the voltage regulator to ensure that it will stick.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
