주요 콘텐츠로 건너뛰기
Apple AirPort Express Base Station Power Supply Kit
34 단계
Apple AirPort Express Base Station Power Supply Kit: 0 단계, 이미지 2개 중 1개 Apple AirPort Express Base Station Power Supply Kit: 0 단계, 이미지 2개 중 2개
  • Give the plastic beads a few seconds to cool, then remove them and mash them together until they form one piece.
  • The plastic beads should be fairly warm still, but their container will likely be extremely hot. Use care when removing and handling the beads.
  • Stretch the glob of plastic into a thin strip that will fill one of the gaps between the case halves.
  • Press the plastic into the crevices and smooth it out with your finger.
  • If the plastic becomes too hard to work with, you can re-apply heat to loosen the plastic.
  • Be cautious if you reheat the plastic while it's in the case. Allow cooling periods between reheating so you don't accidentally de-solder any components.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
