MacBook Air 13" (Late 2010-2017) Fan
  • MacBook Air 13" (Late 2010-2017) Fan
US$39.99
US$39.99
제품 재입고 메시지를 보내드리겠습니다.
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
제품 정보
설명
설명
Replace a defective or noisy fan for your Late 2010 to 2017 MacBook Air 13" laptop with this part.
호환성
MacBook Air 13" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 13" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 13" Early 2017
1.8 GHz
2.2 GHz
MacBook Air 13" Late 2010
1.86 GHz
2.13 GHz
MacBook Air 13" Mid 2011
1.7 GHz
1.8 GHz
MacBook Air 13" Mid 2012
1.8 GHz
2.0 GHz
MacBook Air 13" Mid 2013
1.3 GHz
1.7 GHz
기기 4개 더 보기
수리 경험담
사용자 아바타
andreasjohansson's Story Photo #705878
내 문제
Fan was making a shrieking noise when on - didn't matter CPU load, etc.
나의 수리
Repair was easy - the online guide is so easy to use, and with the right tools it only took us 4-5 minutes.
내 조언
Ha! Once we had replaced the fan, we looked at old one, spun the blades a few times, and out popped a hole-punch hole! And . . .
사용자 아바타
chris's Story Photo #463413
내 문제
The battery on 2 of our Macbook Air's were pretty much dead. One of the Air's fans sounded like a helicopter.
나의 수리
The repair was simple with the iFixit 54 bit driver kit and the replacement parts. The tutorial was spot on with each step.
내 조언
Don't wait to get a new battery. It makes all the difference in the . . .
사용자 아바타
Jesse Russell's Story Photo #352214
내 문제
Fan started making concerning noises.
나의 수리
Every step was clear as day. Took me about 20min and that was me going extremely slow and meticulous. I could do it again in around 7-8min I expect.
내 조언
Just do it the right way with the right parts that are known to work and you'll have no problems.
사용자 아바타
내 문제
Had to replace my macbook display which involves removing the fan, somehow I broke the fan ribbon cable doing this so I had to order a new fan
나의 수리
Went completely pain free, the iFixit guides are always helpful
내 조언
Be REALLY careful with the fan ribbon cable, I thought I was careful the first time but I still . . .
사용자 아바타
내 문제
Daughter stumbled and crunched corner of her laptop, but luckily only the lower case and fan were damaged.
나의 수리
Very easy repair. I skipped step #6. If she didn't have homework I would've had my daughter do the repair herself (with my supervision).
내 조언
Purchased new lower case on eBay. Probably didn't need . . .
사용자 아바타
내 문제
The fan in my MacBook Air was growling. Grrrrrrrrr!
나의 수리
Easy Peasy.... I didn't even lose the screws, and remembered exactly where each went thanks to the overnight shipping. Overnight? Ordered 3:00 pm eastern time, shipped from California and arrived 11:00 am eastern time in Florida. How can they do th . . .
사용자 아바타
내 문제
The fan doesn't work any more
나의 수리
Really easy to access the fan can be replaced quickly. The only little problem is to connect the new one. The spudger help but it's not easy to do it
내 조언
as said in comments step 3 & 6 in guide are not necessary
사용자 아바타
내 문제
Noise from the old fan
나의 수리
Everything went ok
내 조언
No additional advice.
사용자 아바타
내 문제
A piece of plastic from a clothing tag fell into the fan and caused it to stop working. I replaced it using the parts from iFixit. Easy repair - works like new.
나의 수리
Great - the instructions are spot on. Pictures and descriptions are easy to follow. Total repair time was less than 15 minutes.
내 조언
Follo . . .
사용자 아바타
내 문제
Failed fan frightened fellow faculty.
나의 수리
Flawlessly finished, fifteen flat.
내 조언
!fear
더 보기
