소개
Our iPhone 7 Plus is still on the chopping block, but we just can't help ourselves—it's time to look at Apple Watch Series 2. The Series 2 looks all-but-identical to the newly rechristened "Series 1"—but is it the same on the inside? With added features such as built-in GPS, waterproofing, and a variety of new bands and cases, Apple's new wearable was destined for the teardown table. It's time to see if this "ultimate device for a healthy life" has what it takes to go the distance in terms of repairability.
Did you miss our first look at the "best, most advanced iPhone ever"? Hop over to our iPhone 7 Plus teardown and just try to keep up!
Ready to dive in? Keep pace with the latest news from the repair world by following us on Facebook, Instagram, or Twitter.
필요한 것
동영상 개요
Our watches are getting smarter every day. Let's see what the newest generation of Apple wrist accessories has to offer:
Second-generation OLED Retina display with Force Touch
Custom-designed Apple S2 SiP (System in Package)
Built in GPS + NFC + Wi-Fi 802.11b/g/n 2.4 GHz + Bluetooth 4.0
Accelerometer + gyroscope + heart rate sensor + microphone + speaker + ambient light sensor
Water resistance rating (up to 50 meters)
WatchOS 3
With the release of the Apple Watch Series 2, the original Apple Watch has been replaced with the "Series 1"—a new model with a snappy dual-core processor.
The back of the Series 2 is adorned by a familiar quartet of optical polymer lenses protecting a set of LEDs and photodiodes.
Actually, Apple Watch Series 1 has a dual core processor which the original Apple Watch didn’t have. So Series 1 is not the name for the old Apple Watch, but a new model.
This. Please pay attention to this, everyone. We need to remain aware of all attempts at companies and people trying to rewrite history.
In the Original Apple Watch only the Stainless Steel model and the Edition (gold) model had a Ceramic back with sapphire lenses and the Sport edition had a composite back. Now all Series 2 models have a Ceramic back except the Series 1 model.
This. Coming to see this. Please pay attention to this, everyone. All series 2 models is equipped with ceramic back. Even with aluminum case. That's the difference between series 0(composite back on aluminum), series 1(composite back), and series 2(all ceramic back).
Carry the same screen the series 1 and the series 2 42mm?
이 단계에 사용된 도구:iOpener$12.99
Armed with knowledge gleaned from the original Apple Watch and our expertise wielding an iOpener, we're ready to bust through the adhesive and pop off the screen.
A knife, a pick, and a spoon full of gumption later and we're in!
Externally, the Series 2 bears a strong resemblance to its older sibling—but once inside, we find a set of ZIF connectors in place of the awkward press connectors of yesteryear.
And tucked away on the back of the display we find a whole host of control hardware:
Apple 343S00092
20211CP TD1628A
NXP 67V04 NFC Controller (also found in the iPhone 7 Plus)
Please update this to show how to disconnect the ZIF connectors. I had to resort to just yanking them out and then shoving them back in, which seemed to not affect the display at first but after a day the screen is no longer working at all, so I’m guessing I destroyed the connectors and therefore the watch, permanently.
Hi Bryan, thanks for repairing your Apple Watch Series 2. Unfortunately this (and any other) teardown is not meant to be used as a guide. But stay tuned, we’re in the process of preparing Series 2 guides (including the display). If you’re unsure about a connector in the future, you can look them up here: 케이블 커넥터 인식 및 분리
이 단계에 사용된 도구:Mako Driver Kit - 64 Precision Bits$39.95
We slide the remaining band away from the body of the watch and start digging for the battery.
Just like the battery bracket in its cellular-capable counterpart, this piece is held in by a less-than-friendly tri-point screw. Thankfully, our 64 Bit Driver Kit is up to the task!
With a deft flick of our spudger this watch is rendered powerless.
So indeed according to the image the wifi antenna has moved to the right near the Digital Crown rather than the more familiar one we saw on the first generation on the top row just above the Taptic Engine and the speaker module
Welp—as they say—if it seems too good to be true, it probably is.
Compared to last year's Apple Watch, the underside of the Series 2 battery reveals enough
chewing gumadhesive to hold an iPad screen in place. -
We've never backed down from a sticky situation before, and this is no exception. We pick and prod, peel and pull the adhesive off the little power pack—with enough coaxing, it will come clean and reveal its secrets.
With the glue stripped from the back of the battery, we get a closer look at its impressive specs. This cell is rated at 3.77 V and 273 mAh to yield a whopping 1.03 Whr of power.
Apple says the Series 2 will have about the same 18-hour battery life as the original Apple Watch, so that GPS must be power hungry.
I am glad the battery is bigger than the original Apple Watch. As a Pebble watch owner, I have been leery of the low battery life of the original Apple Watch. I would like to see a teardown of the new Apple Watch Series 1. I would like to see if the new battery in the Apple Watch Series 1 really is the same size as the new Apple Watch Series 2. (I know that the “published” battery life shows them with similar battery life's, but I take that published data with a grain of salt…) The GPS and water proofing of the Apple Watch Series 2 are not features that are particularly important to me, but battery life is. If the new Apple Watch Series 2 has a bigger battery than the new Apple Watch Series 1, that might make me look into the Apple Watch Series 2 (I’d keep GPS off), but if they both have the same battery, then I would lean toward the new Apple Watch series 1.
Can you measure the dimensions of the battery and post them?
Alex how old is your battery?
Mine is over 2 years, reports say battery still fine but it doesn’t take charge well and having issues updating.
MrDazFlash - 답글
이 단계에 사용된 도구:Tweezers$4.99
With the Taptic Engine extracted, we inspect the antenna module found tucked away at the top of the watch.
Enough gawking—it's time to get our tweezers on what's left of this wearable.
Any suggestion of whether the new antenna will give better wifi connectivity than the original had?
hi where can i buy this part?
caiomarchi - 답글
Hiding out on the outer rim, we find a complex cable assembly—home to the microphone and speaker.
The Apple Watch Series 2 is trying to make a splash while keeping dry. This requires no shortage of gaskets and o-rings.
How well do these gaskets and o-rings keep water out? The Apple Watch Series 2 resists water intrusion to a depth of 50 meters, under ISO standard 22810:2010. This means it will be fine in a pool, but may fail during certain activities.
There's no barometer on the S2 though is there?
Did someone say ingress protection? This highly-touted speaker is equipped to deal with incoming water rather than fight it.
Unlike the original Apple Watch's speaker—which would simply flood when underwater—this module is designed to fill with water, then vibrate to pump excess water from the body of the speaker.
There's one last piece barring us from reaching the belly of the beast: this ribbon cable assembly, where the Home Button and Digital Crown encoder reside.
Luckily, no teardown can be thwarted so easily. We quickly move past the gangly assembly to get at the core computer in this little wearable wonder.
And, in keeping with the tradition of last-minute tool modifications, we make use of our all new Apple Watch Opening Pick to lift the System in Package out of the rear enclosure.
And we finally reach the much awaited Apple S2 SiP—complete with the dreaded resin enclosure.
On the top of the SiP, tucked into the upper left corner, we spot a tiny pair of components:
Bosch Sensortec BMP280 Barometric Pressure Sensor
Likely an iteration of STMicroelectronics C451 gyroscope + accelerometer found in the original Apple Watch
Any reason why you guys did not open that shiny module? Would be interesting to see what kind of memory is in there as well as the application processor to memory interface.
From the first Apple Watch Teardown: "Unfortunately, our first look is obstructed—that S1-emblazoned silver cap isn't a cap at all. It's a solid block of plasticky resin, hiding treasures deep within."
This is what they were referring to as the "dreaded resin enclosure"
That is not a second microphone, it is obviously a barometric pressure sensor from Bosch Sensortec
Apple don't claim the watch has a barometer. Does the tear down indicate it has one? Did the first watch have this component in it?
Hi Dan, No the 1st Apple Watch doesn't have a barometer, but they learned that it is very important to get accurate calorie measurement, Additionally you get the absolute height and a weather station.
Any thoughts on why the watch does not count stairs climbed despite the presence of a barometer?
It looks certain part like left side of middle area thinner than the other area. Is that any reason ?
All that's left between us and complete teardown glory is the sensor array, housed in the watch's back cover.
The four-sensor array includes infrared sensors, visible-light LEDS, and photosensors to track your heart rate throughout the day.
With the sensor assembly removed, we spy what we assume is the inductive charging coil left behind in the cover.
NXP Semiconductor Analog Front End Controller (likely)
No adhesive this time? Is this snap-in like some manufacturers do with their traditional watches?
How to get that sensor any idea guys!!
Sariga K V - 답글
And that's a wrap! With our Apple Watch torn asunder on the teardown table we step back to pick up the pieces—and hope it's still waterproof when we put it all back together.
- While not an industry standard, the watch band is easily removed and swapped out for a replacement.
- Removing the screen is difficult, but not impossible—it's the first component out, and is connected with easy to use ZIF connectors.
- Once you're inside, the battery is fairly easy to remove—if you have the proper tri-point Y000 driver.
- While not proprietary, incredibly tiny tri-point screws are a repair hinderance.
- Replacing any of the component cables requires microsoldering—but does not require removing the SiP as in the previous generation Apple Watch.
- The fully encased S2 system makes board-level repairs impossible.
최종 결론
수리 용이성 점수
(10은 가장 쉬운 수리를 뜻합니다)
댓글 56개
Here we go ....! The best part of staying up late is to be the first to get hands on teardown these little monsters packed with loads some of the most intricate and advanced pieces in tech manufactured to date
Hmmm... does this mean the Apple Watch might actually be repairable by repair shops? The display looks a lot easier to take apart. Minus the likelihood that repairing it may render it not "swim proof" anymore.
True I've had loads of issues before while repairing the Apple Watch specially with the glue that becomes almost useless the minute you pop the screen off and not to forget the tiny metal bracket holding the display and digitiser flex in !! This indeed looks repairable
I've never repaired it, but I was warned not to. Perhaps now this will change with a few ZIF connectors.
It isn't as easy as it looks ! I was warned by many too ....I infact ripped one of my first motherboard flex cables off in the past ...by curiosity didn't stop me ! You always get it right the next time ! I'd suggest on picking up one of the demo units from eBay to try your stunts right as they are as low as $100 to see your first teardown come off and then you can repair your customers watches easily after you tear one down for yourself
Great idea! I definitely need to pick one up first to test it myself.
I'll have to wait for a month atleast before I can get my hands on ! Moreover the 2nd gen ones will be out late on eBay ...! And the shipping could take ages if your not in the states but it's worth it still
Does it have the same diagnostic port Apple Watch Beta had?
According to settings it can store up to 2gb of songs
Jesus! The capacitor in step 4 picture 3 on the right is nearly falling off! Quality control is minimal here!
the question is how was the metal shielding removed. If you see earlier photos, those areas were protected. Those protection needs to be removed before 3rd photo could be taken. If excessive heat was applied, of course the solders holding those components would melt, causing them to look like that.
Yes, we had to desolder the metal shield. That damaged some components underneath. If you've got a better technique for removing these shields, we're all ears!
Kyle Wiens I'd love to see you guys teardown the S2 from the metal housing if that's a possible ! I know it's a destructive process at times but if you could I'd be greatful
See Step10, there is an amazing multi-pin connector!
Does anyone know who is the supplier of this connector?
Maybe the connector is from murata!
And where's the "service port"? no word about it...
What about the second mic hole> Not found on the original Apple Watch!
Alex Smith - 답글
I wonder, they mentioned the series 1 will get the dual core CPU, but not if the GPU and the rest of it were the same. Are they?
That's probably a question that' down to Chipworks. And how about RAM?
Zone of Tech says it has 1GB of system ram up from 512MB in the original models.
I want to buy one.
I've been trying to get that info, and nobody from iFixit or anywhere else for the matter is able to reply...
My series 2 has some little doors in the same place as the first generation, however it looks smaller this time - it is smaller in length than the button for band release...
Afew weeks ago I bought on flea-bay a "Smart Watch" for all of 16 GBP - this has a removable battery and provision for a SIM card and extra memory micro-SD, so is a true "Wrist Communicator" - (and if you don't know what that means look up Dick Barton !).
So this cheap Chinese watch goes further than Apple - and does a variety of things; above all is the ability to dispense with a paired phone. It is called "APLUS" and I have no connection with the seller other than being a satisfied user.
How do the Chinese do this so cheaply; how long before Apple will offer an internal SIM ?
Last time the prototype Gyro was published as InvenSense. That was a good guess based on the fact InvenSense is Apple's go to company for motion technologies. But it ended up being STM. That was because STM was first there in the original design.
Now the guess is "Likely an iteration of STMicroelectronics C451 gyroscope + accelerometer". Based on the fact STM was in on iWatch1. But the iWatch2 has diiferent requirements. This gyro must provide a navigation solution and turn off the power hungry GPS 80% of the time. InvenSense excells in this capability.
I would be highly surprised if InvenSense does not have the best 6 axpoThe real question in my mind is did Apple use InvenSense Software? If so better margins should be coming.
How much storage does it have??
According to the info in Settings -> About in the watch Series 2, 38mm, it has 5.7 GB internal capacity.
Apple 343S00092 is a dialog semi PMIC
whiteriver - 답글
Can you comment on this additional seam that can be found on this Reddit thread? https://www.reddit.com/r/AppleWatch/comm...
Anyone knows how the antennae RF connections are done?
Is there an improvement in the heart rate sensor? I know I'm my Apple Watch Series 1 (sports version) it seems a little slow to pick up my heart rate and also refresh when I begin exercise. Anyone know how often it 'refreshes' also?
hey, do you have any ideea is the sapphire led display from series 1 compatible with series 2 ? somehow I broke mine and i can't seem to be able to find one to buy and I'm still trying to avoid the apple store since it was a gift and haven't got applecare+ for it ...
Hello, I have an Apple watch 42 mm the first model q was released. It was working normal and suddenly started to restart and stay in that infinite lopp. Is there anything that can be done to reverse this situation?
Wonder what happened with the barometer. Maybe they disabled it last minute to save on battery.
Cory Mayer - 답글
In regards of how to remove the shielding without suffering component damage, you could physically cut it off. I did that with an iPhone 5 logic board, although it damaged some coils. There must be a more precise way to machine it off.
Hi guys. Excelent tear apart guide. Just wanted to ask if by replacing the screen on the watch series 2, is there any way to get the watch sealed again so one can swin with it with no problems?
I would love to see some detailed photos of the chips on the motherboard - to get an understanding of the specs of the components - GPS, Motion detectors, memory, CPU etc.
Alan Smith - 답글
That’s a little beyond iFixit’s abilities in a case like this, but our friends over at TechInsights have taken it a lot further.
Although board level repairs aren’t viable, is it possible to replace the board of an apple watch? When putting the watch back together, did it still seem waterproof?
Logan Jung - 답글
My apple watch display broken so I replaced my watch display but now watch can’t pair to my phone what is the reason why my watch not pair to my phone
Sam shakya - 답글
Someone tell me about where can i buy back aluminium cover (sideral grey/nike edition) replica of apple iwatch series 2 (42mm)?
What's between the sapphire crystal and OLED display?
mark.albrechtsen - 답글
