주요 콘텐츠로 건너뛰기
We got up this morning to news that the new iMacs were out, so we knew what we had to do: start sharpening our suction cups!
Thankfully, this iMac model opens in the same way as previous generations. All you have to do is pull off the magnetically-held display glass with two medium-size suction cups, and then remove the screws holding the LCD in place.
But what lies inside? Only one way to find out...
필요한 것
도구
더보기...
해당 분해도는 수리 안내서가 아닙니다. iMac Intel 21.5" EMC 2428 수리는 자사의 서비스 설명서를 사용하세요.
  1. iMac Intel 21.5" EMC 2428 Teardown, iMac Intel 21.5" EMC 2428 Teardown: 1 단계, 이미지 1개 중 1개
    • Introducing the new 21.5" iMac, now featuring additional features such as a Thunderbolt port and a quad-core processor.
    • Tech Specs:
    • Quad-core Intel Core i5 with 6MB on-chip shared L3 cache
    • 500 GB Western Digital 7200 RPM hard drive
    • 4 GB of RAM
    • AMD Radeon HD GDDR5 graphics processor
    • Thunderbolt port
    • 802.11n Wi-Fi and Bluetooth 2.1 + EDR
  2. iMac Intel 21.5" EMC 2428 Teardown: 2 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 2 단계, 이미지 2개 중 2개
    • Ports on the backside of the iMac include:
    • Audio line out
    • Audio line in
    • Four USB 2.0 ports
    • Firewire 800 port
    • Thunderbolt port
    • Gigabit Ethernet port
    • The SDXC card slot is located underneath the optical drive.
  3. iMac Intel 21.5" EMC 2428 Teardown: 3 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • We call upon our trusty heavy duty suction cups to aid us in separating the glass panel from the front bezel.
    • The LED-backlit glossy widescreen display is secured to the front bezel by several T10 Torx screws.
    There are four Torx 10 screws on each side of the display. There are other Torx 9 screws in this area - they do not need to be removed, as they hold other pieces, like the camera, to the frame.
    When lifting the display screen, lift it only 30°, or else you'll accidentally pull out either the sync cable, the power cable or more likely, the data cable. You'll want to know where they came from!
    charleslindsay - 답글
  4. iMac Intel 21.5" EMC 2428 Teardown: 4 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 4 단계, 이미지 2개 중 2개
    • We carefully lift the LED-backlit display from its recess in the front bezel.
    • The 21.5-inch (viewable) LED-backlit glossy widescreen TFT display has support for millions of colors, with a maximum resolution of 1920 x 1080 pixels.
    • The LED display is manufactured by LG and is denoted by its model number LM215WF3.
    • This is the same display used in the previous generation 21.5" iMac.
    Eu troquei HD mais a tela não está ligando o sistema está ligando estou usando uma tela paralela normal mais a tela do iMac está sem ligar
    Alexandre - 답글
    You left out a bunch of huge steps there. How about some disconnection points?!
    Mattt Potter - 답글
  5. iMac Intel 21.5" EMC 2428 Teardown: 5 단계, 이미지 1개 중 1개
    • Similar to the Thunderbolt IC we found in the MacBook Pro 15" Unibody Early 2011, the iMac Intel 21.5" EMC 2428 features the Intel L102IA84 EFL Thunderbolt port IC.
    • Thunderbolt claims to provide 10 Gbps throughput for both input and output. It appears that both PCI Express and DisplayPort receive their own 10 Gbps data channel. That's nice, as you don't want your display competing with your external hard drive for bandwidth.
  6. iMac Intel 21.5" EMC 2428 Teardown: 6 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 6 단계, 이미지 2개 중 2개
    • Disconnecting three antennas and removing a few screws allows the AirPort card to pop out of its socket.
    • The big winner in the wireless communication area this time around is Atheros.
    • At the heart of the Wi-Fi card is an Atheros AR9388-AL1A 802.11n wireless LAN chip.
  7. iMac Intel 21.5" EMC 2428 Teardown: 7 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 7 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 Teardown: 7 단계, 이미지 3개 중 3개
    • In the next few steps, we remove many components that are very similar to the last 21.5" iMac.
    • The WD Caviar Blue hard drive is held to the front bezel by a few screws and, as always, the SATA data/power connectors.
    • The WD Caviar Blue drive is a non-standard SATA drive. The power connector features 7 pins, rather than the standard 4. The drive also has non-standard firmware. This means you can only use Apple's own hard drives and not any standard after-market SATA drive.
    • Removing the power supply requires disconnecting the AC inlet cable from the logic board.
    • The LED driver board comes out next after successfully removing the power supply.
    I am an Apple technician and this is incorrect. Any standard SATA drive (SATA, SATAII or SATA3) will work in any iMac. It is recommended you use a SATAII as this is native to the iMac, SATA3 will derate to SATAII and SATA will run only at the drives supported SATA speed.
    Granted the firmware is different on the Apple drive that comes in the machine or in our hard drive upgrades, but the standard firmware with your aftermarket drive will still work as good!
    inthatribe - 답글
    Wow, way to NOT read the description.
    No one is contending an aftermarket drive wouldn't *work*, the issue is that an aftermarket drive causes the fans to run at full-power continuously, because it does not properly inform the fan controller of the drive's temperature.
    Fake Name -
    @ Fake Name “This means you can only use Apple's own hard drives and not any standard after-market SATA drive.”
    I think there’s no other way to read that line except that it is saying that “you can ONLY use Apple’s own hard drives and NOT ANY STANDARD after-market SATA drive.” … which is plain wrong as inthatribe states.
    Passerby -
    Is this a 3Gb/s or a 6Gb/s SATA-bus?
    Joachim - 답글
    WOW, way to not write a description clearly!
    This in no way implies that an after market SATA drive can be used. On the contrary, it plainly states that one can not be used by the usage of the words “can only use”.
    It would be helpful here to use correct language as well as elaborate about the issue.
    bbc - 답글
    The WD HD is held by just two Torx 10 screws. Remove those and slide the unit out of the two holes at the back, then the two multi-pin connectors are easily removed. When re-assembling. plug in the connectors before locating the unit in the bezel and replacing the two screws.
    John Wallace - 답글
  8. iMac Intel 21.5" EMC 2428 Teardown: 8 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 8 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 Teardown: 8 단계, 이미지 3개 중 3개
    • Good-bye optical drive, we hardly knew ye...
    • The new iMac carries a Sony Optiarc optical drive, model number AD-5690H.
    • The area shaded in red in the third picture is presumably where the optional SSD is housed. The three mounting points within the shaded area have nothing attached to them in our machine, since this option is only available on 2.7 GHz 21.5" iMacs.
  9. iMac Intel 21.5" EMC 2428 Teardown: 9 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 9 단계, 이미지 2개 중 2개
    • The audio line-in and audio line-out ports are embedded deeply inside the front bezel. After removing their mounting screws, we removed the entire assembly from the case.
    • Another leftover from the previous generation, the IR board, can simply be lifted straight up and removed from the iMac's front bezel.
  10. iMac Intel 21.5" EMC 2428 Teardown: 10 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 10 단계, 이미지 2개 중 2개
    • Several Torx T10 screws hold the logic board in place. We make short work of them.
    • If you want to remove the board, you have to snake it out from the rest of the iMac -- a combination of pulling up, as well as away from the casing. After a little bit of jiggling, it comes right out.
  11. iMac Intel 21.5" EMC 2428 Teardown: 11 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 11 단계, 이미지 2개 중 2개
    • Is it just us, or does the logic board layout (with heat sinks) look a bit like the original Starship Enterprise?
    • In usual Apple fashion, one heat sink is reserved for the CPU, while the other oversees the GPU.
    • And, in usual Apple fashion, you have to void the warranty in order to get a peep at the processing power underneath.
    • In the RAM department, this iMac has space for four 204-pin PC3-10600 SO-DIMM chips.
    It looks like they are but I'd just like to confirm that all four RAM slots are still accessible from the grill on the bottom?
    Daniel Trogdon - 답글
    Yup, there's a small access door along the bottom edge of the iMac with three #1 Phillips screws that can be removed to access the four RAM slots.
    Andrew Bookholt -
  12. iMac Intel 21.5" EMC 2428 Teardown: 12 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 12 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 Teardown: 12 단계, 이미지 3개 중 3개
    • With a bit of magic, the GPU heat sink detaches from the logic board, exposing the AMD GPU.
    • The main chips on the GPU include:
    • AMD Radeon HD 6750M GPU
    • Four Hynix H5GQ1H24AFR T2L 1 Gb GDDR5 SDRAM chips (totaling a cumulative 512 MB)
    Why would 4 1Gb modules add up to a cumulative 512MB ?
    lz4broc - 답글
    Presumably 4Gbit, so 1/8th of a GByte.
    Googlyhead -
    Or;
    4 x 1024 x 1024 to get the actual number of bits.
    divide by 8 to get bytes.
    Divide by 1024 to convert to MegaBytes.
    (or simplify by removing one multiply and one divide by 1024)
    Result = 512 :-)
    Googlyhead -
    can we replace a higher performance display card?
    louis0619 - 답글
  13. iMac Intel 21.5" EMC 2428 Teardown: 13 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 13 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 Teardown: 13 단계, 이미지 3개 중 3개
    • We'll do almost anything in the name of science.
    • After popping off the CPU heat sink, we can get a good look at the Core i5 processor.
    • Our machine is powered by a quad core 2.5 GHz Core i5-2400S CPU with 6 MB of Intel Smart Cache.
    • Thankfully the CPU and GPU on this machine have proper amounts of thermal paste applied, a happy depature from the gobs applied to the MacBook Pro we recently took apart.
    I may sound silly but can you actually change/upgrade the CPU from the I5 to an I7 by yourself and, with the 27" iMac there are 4 ram slots is this the same on the 21.5" Apple originally said it only had 2 but now they say you can upgrade the 21.5" to 16GB Ram (4x4GB)? Thanks
    Zed - 답글
    For what it's worth, you can now get 8 GB SODIMM ram sticks, so the "Upgradeable to 16GB" specification does not necessarily imply it has 4 RAM slots.
    Fake Name -
  14. iMac Intel 21.5" EMC 2428 Teardown: 14 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 14 단계, 이미지 2개 중 2개
    • The main chips on the logic board include:
    • 2.5 GHz quad-core Intel Core i5-2400S CPU with 6 MB of Intel Smart Cache.
    • Intel BD82Z68 Platform Controller Hub
    • Broadcom BCM57765B0KMLG Integrated Gigabit Ethernet and Memory Card Reader Controller
    • Cirrus 4206BCNZ audio controller
    • SMSC USX2061 (we believe this a USB 2.0 Hub Controller Family)
    • Intersil ISL6364 CRZ Single-Phase Synchronous-Buck PWM voltage regulator for GPU core power applications
    • Intel L102IA84 EFL Thunderbolt port IC
  15. iMac Intel 21.5" EMC 2428 Teardown: 15 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 15 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 Teardown: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Vise
    $19.99
    • Next, we can remove the Bluetooth board from the iMac.
    • With the help of our trusty iFixit vise (which is made of the same material as our spudgers, and is ESD-safe), we're able to desolder the shield covering the little Bluetooth board to reveal the chip goodies underneath.
    • At its heart lies:
    • Broadcom BCM2046 Bluetooth IC
    • 256 KB of SST 39VF200A CMOS Multi-Purpose Flash (MPF)
    • We found this same chip a long time ago in the first MacBook Air.
    здравствуйте, подскажите пожалуйста какие ещё поддерживает процессоры этот компьютер? на какой можно заменить чтобы всё работало?
    грустный кот - 답글
  16. iMac Intel 21.5" EMC 2428 Teardown: 16 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 Teardown: 16 단계, 이미지 2개 중 2개
    • iMac 21.5" EMC 2428 Repairability Score: 7 out of 10 (10 is easiest to repair)
    • The front glass panel and LCD are quite easy to remove for accessing all the hardware underneath.
    • RAM, hard drive, and optical drive can be replaced with relative ease, as long as you don't mind taking out the LCD (for the drives).
    • Limited use of adhesives (pretty much all the fasteners are mechanical) make disassembly pretty straightforward.
    • Replacing the CPU and GPU is possible to do, but you need to remove the logic board from the computer.
    • Removing the logic board is a pain, since you have to disconnect a bunch of connectors, and wiggle it out of the machine.
    • Making the LCD and glass spotless when reassembling the machine is nearly impossible. (compressed air is useful when trying to remove dust from the display or glass panel)
    • Like being able to see the guts of your machines? Check out our iPhone 4 transparent rear panel!
    Still lots of messy cables and foil inside... the day that Apple are proud enough to show off the insides of the current iMac design (as they did with the G5 and in the past with the MacBook Pros, MacBook and Mac Mini), is the day the have finally perfected the form both inside and out.
    Mike Hopkins - 답글
    I got lightning stroke through the ethernet/gigabit port. Now the imac won't up. When we looked into the logic board and light it up, there was a green light blink in the board but not all. Is there any chance that the bad ethernet cause it failed to boot? Can we detach the ethernet port off of the logic board? Thank you.
    #we have tried with a good psu, they results the same.
    mark - 답글
작성자
13다른 기여자 명과 함께
Miroslav Djuric
159,524 평판
안내서 144개를 작성함
댓글 30개
In the location you suspect an SSD to reside (in models so equipped) is a spare power connector and SATA cable connector available to add an SSD drive at a later date?
Gregory Cox - 답글
I'd like to know that, too. If so, it would be awesome!
Pierre Minnieur -
I'm dying to know this too! Are there power/data cables in place? Are the mounting points ready to accommodate a drive?
I'm afraid this teardown won't answer these questions. Will you be cracking open a 27" unit?
Cliff Norton -
The cable was not there, but there is an extra standard SATA data socket on the board along with a proprietary power socket labeled "SSD Power". Not sure where you could get the cable to make it work though.
Andrew Bookholt -
In step 11 you mention how lifting the heat sink off will void the warranty.
Surely you have voided the warranty already by now.
Can I open up my brand new iMac, put in a better hard drive and still be within my warranty? I am guessing I would be laughed right out of the genius bar, but if it isn't so .. do tell.
sprockety - 답글
We didn't see any tamper-evident seals on any component other than the CPU heat sink. If you were careful and clean about things, I don't see how they could prove that you opened your iMac and swapped out a hard drive if you put the OEM hard drive back in when you would theoretically take it in for service. I thought it was pretty surprising that they didn't even put a seal on the GPU screws.
Andrew Bookholt -
If you replace the hard drive with another one, you can end with HDD fan blowing at full speed constantly (that is rather noisy).
You will need an HDD with Apple firmware.
Also, get an anti-static brush for cleaning the display and glass.
Yakov Shapovalov -
Is that 204-pin pc3-10600 SO-DIMM chips?
Niklas Saers - 답글
That is correct.
Andrew Bookholt -
Yes, the RAM is 1333MHz DDR3 PC3-10600 SDRAM.
However, you can use any DDR3 RAM.
RAM with a higher speed (like 1600MHz) will just downclock to 1333MHz; there is no downside to using RAM that is faster than 1333MHz.
RAM with lower speed (like 1066MHz) willl cause all the RAM to run at the speed of the slowest module; the system will still run fine with slower RAM, it will just be a bit slower.
Langdon Staab -
Perhaps if you guys want to be 'really' professional, you might consider Anti-static procedures and a pair of gloves next time, instead of acting like complete noobs, by not providing such instructions you just increase the return rates of Mac products, because of idiots following these instructions.
steve B - 답글
Perhaps if you want to sound 'really' professional and not like a total noob, you might consider going back to 7th grade to learn how to properly form a sentence.
Project Mayhem -
And how do you know they didn't follow anti-static procedures? Are you able to psychically determine that the guy in the photos doesn't have an anti-static grounding strap pushed up one arm? Or maybe they're *really* professional, hand have anti-static matting and heel-straps, which don't require putting anything on your arms at all.
Just FYI, this is a *teardown* - that means it's NOT a DIY instruction set, and doesn't bother with discussing safety measures for taking care of your electronic.
Fake Name -
Did you have access to the stand connector (to remove the stand) once you removed the hard drive? Would stand removal be easier on this model compared to earlier models?
John - 답글
I'd like a little more information on the WD Caviar Blue drive. The link shows drives up to 6Gb/s but only 1TB in capacity. I know this is the small iMac but what drive is Apple using in the 27" iMacs that can be upgraded to 2TB drives? I'm also not seeing anything on the WD website that talks about a 7-pin connector. Does the drive actually have an Apple P/N on it?
plink53 - 답글
Could you tell me what the chips are that provide the Firewire 800 interface? (I have had two 27" iMacs, one from Oct 2011 and another from April 2012, both of which suffer from finder lockup every week or two when I leave connected two F800 daisy-chained v3 3TB LaCie 2d Quadra drives. LaCie tech support has told me that "some Macs have incompatible interface chips and some don't". I'm trying to learn more about this so that I can identify an iMac that will not lockup sporadically when used with these external drives.)
Eddie - 답글
Wait, you have finder lockups every week or two?
Unless you just leave the computer on a table and look at it, that's fuċking fantastic. I'm lucky if I can manage a day without multiple finder crapouts. Finder is a terminally şhitty piece of software.
A lock-up per week? Get over it. And remember, Command+Option+Esc is your friend.
Oh, incidentally, LaCie is almost definitely talking out their åss about the "incompatible interface chips". They just don't know what's wrong, and are making something up to get you to go away.
Fake Name -
can i upgrade my iMac (mid 2011) from i5 to i7?? thanks
isaincuiulian - 답글
Might be a bad idea.
The PSU is probably too weak for an i7.
It was designed for a less power-hungry i5.
I suppose you could reduce power consumption by removing the bluetooth card, IR reciever, ODD, sd card reader and camera.
And turn down the brightness, and use Macs Fan Control to cool the CPU extra well.
However, you can do anything you want.
The only limits are time, money and effort.
Langdon Staab -
Hi, my iMac (buyed on refurb) is a EMC2428 but hdd is a Seagate sata2 500Gb
Kristof - 답글
What's the relevance of the SD C2 numbers on the screen? I need a new one and have seen variants of these numbers.
Phil - 답글
I've been looking for a video or tutorial that shows if there is a way to repair the USB PORT, actually is half of them that doesn't work, will I need to replace the all logic board? :(
Guillermo Estrada - 답글
Does it support sata 6Gbps?
JGabriel - 답글
Changing out the hard drive- taking the 500 “Apple” drive out and replacing it with a 1 TB Firecuda hybrid. Do I need to use the fan control software or the OWC adapter connector/board? The Apple drive has the 7 pin interface, my new one does not. Assume it is for the temp sensor?
OK, so probably need the connector fix or fan software? Appreciate an answer. Thanks!
Carl Schultz - 답글
Hello I have the apple A1311. Mid 2011. 21” it is not powering on . When I pu
lug it in to power outlet the1 of 4 led lights on the motherboard light up and when I press the power button it turns off and the computer does not power on …what do you think is the problem?
Jermaine Willock - 답글
Not sure who needs to know this still in 2022 but i pulled my mac out of storage to get my files it booted but was slow now it wont boot or repair disk. I dont have suction cups but a small razor blade on the edge of the front glass can pry a gap for you to grab and pull off. May damage some of your aluminum but in my case i didnt really care the the thing is old.
Patrick Riley - 답글
which ox install this imac 2011
please tell me what version of ox will be installed on it .all my work is on hold . please tell me.
Muhammad iftikhar - 답글
2011 max system is should be 10.13
JERRY0421 -
Look up OpenCore Legacy Patcher.
Langdon Staab -
An electrically grounded normal vise is also ESD-Safe.
What is the significance of a special "ESD-Safe iFixit vise"?
Langdon Staab - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 135
지난 30일: 696
전체 시간: 783,179
