주요 콘텐츠로 건너뛰기
This is the first of three iPod teardowns this week! We'll be taking apart the new iPod Touch and iPod Nano the moment we get our hands on them. Stay in the loop on twitter as the week progresses.
In case you missed it, last week we celebrated a major milestone. In addition to enabling Apple repair, we now have parts and repair manuals for most game consoles! We decided to celebrate by taking a trip through time and ripping apart five retro consoles:
Still want to keep your old Shuffle running? We have complete iPod Shuffle repair manuals and parts.
필요한 것
도구
더보기...
해당 분해도는 수리 안내서가 아닙니다. iPod Shuffle 4th Generation 수리는 자사의 서비스 설명서를 사용하세요.
  1. iPod Shuffle 4th Generation Teardown, iPod Shuffle 4th Generation Teardown: 1 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown, iPod Shuffle 4th Generation Teardown: 1 단계, 이미지 2개 중 2개
    • Apple's latest incarnation of the Shuffle bears little resemblance to its immediate predecessor.
    • Although the Shuffle features "new, smaller packaging," it doesn't feature a similarly resized shipping box. Apple could have shipped 30 iPod Shuffles in this box. Literally.
    • Its Apple model number is A1373, updated from the previous Shuffle's A1271 designation.
    I love that iPod shuffle shipping box.
    PrizedPixul - 답글
  2. iPod Shuffle 4th Generation Teardown: 2 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 2 단계, 이미지 2개 중 2개
    • The 4th Gen Shuffle is priced at a paltry $49.99! The original iPod shuffle cost $99, and had only 512 MB of storage.
    • There's a button just for VoiceOver: push once for artist and song, twice for battery status, and hold for playlist menu.
    • Apple admitted that people actually like buttons and brought them back for this generation.
    • Pshhh! Those of us with 3rd Gen Shuffles just printed out this convenient chart and carried it around for reference.
  3. iPod Shuffle 4th Generation Teardown: 3 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 3 단계, 이미지 2개 중 2개
    • Here's the full lineup.
    • There seems to be pattern here: skinny, fat, skinny, fat. It seems like Apple can't decide what shape they like best.
    • iPod Shuffle 4th Generation:
    • Height: 1.14"
    • Width: 1.24"
    • Depth: 0.34"
    • Weight: 0.44 oz.
    • A bank was robbed last week in Ba Sing Se. Witnesses were given this lineup to identify the perpetrator.
    That robot is oddly familiar......
    Alex Jansen - 답글
  4. iPod Shuffle 4th Generation Teardown: 4 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 4 단계, 이미지 2개 중 2개
    • Although this step makes it look super-simple to open the Shuffle, it's not. It took us a good half hour of prying and heat-gunning to open the little guy.
    • Pro tip: Aluminum gets hot when it's heated!
    Sorry if I'm missing something here, but what is that secured to the rear panel (visible in step four)? I see four screws holding the clip onto the rear panel, but there doesn't seem to be any teardown of that segment of the Shuffle.
    threebkk - 답글
    Towards the bottom right, there appears to be a small tab to help keep the back attached. The black goop I'm assuming is glue or a seal of sorts. And the grey-ish blob towards the top right looks like foam with probably a metal mesh surrounding it. I'm not sure what the technical name is, but that type of foam is common in electronics.
    Mitchal Fej -
    I'm gonna try to remove the back cover with minimal prying to reduce cosmetic defects. The plan is to somehow remove the spring loaded clip by pushing out the lever pin, then drilling holes along the edge of the over wherre the 3 little hooks are (In this image, where the right thumb is touching. https://d3nevzfk7ii3be.cloudfront.net/ig...).
    It would be great if someone could provide a closer look at where exactly the hooks are so I can position my 1.5mm drill bit better. Also, if you can to figure out how to remove the spring loaded clip mechanism without going through the 4 screws, that'd be awesome! I suspect the pin is held in place by just adhesive, but don't want to risk pushing too hard and causing defects. :(
    Sam Waiban - 답글
    I just quit all together… You didn’t lie about the back being hard to remove.
    hunterlawson73 - 답글
    Dank pods is right about you slipping and cutting your self and you don’t even realize it until you look down and see blood
    The Rebble - 답글
  5. iPod Shuffle 4th Generation Teardown: 5 단계, 이미지 1개 중 1개
    • The exposed internals.
    • The logic board is stuffed alongside the battery in the outer case.
    • Notice the glue residue along the edges of the opening.
    • Apple press-fit and glued the back clip onto the body. No wonder it was such a doozy to open!
  6. iPod Shuffle 4th Generation Teardown: 6 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Even the seemingly simple task of disconnecting the control pad ribbon cable turns out to be quite a chore when the connector is 1/8" wide.
    • We have a feeling that as technology advances, we'll need smaller and smaller tools to take devices apart. You won't be able to see our hands in pictures, just little pointy tweezers.
    • We already have a microscope ready and waiting in the back room for when that time comes -- but we're not there quite yet (thankfully).
  7. iPod Shuffle 4th Generation Teardown: 7 단계, 이미지 3개 중 1개 iPod Shuffle 4th Generation Teardown: 7 단계, 이미지 3개 중 2개 iPod Shuffle 4th Generation Teardown: 7 단계, 이미지 3개 중 3개
    • Our huge #00 screwdriver makes short work of the logic board screw.
    • A plastic opening tool is needed to lift the battery off the light adhesive holding it to the case.
    • After the battery is out, a small plastic logic board retainer must be removed with none other than a dental pick.
  8. iPod Shuffle 4th Generation Teardown: 8 단계, 이미지 1개 중 1개
    • We remove the logic board and battery together from the iPod, because Apple once again chose to solder the battery to the logic board.
    • The loss of user-serviceability is the price we pay for small, sleek design.
  9. iPod Shuffle 4th Generation Teardown: 9 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 9 단계, 이미지 2개 중 2개
    • Removing the last four screws in the iPod Shuffle, which secure the control pad to the front of the iPod.
    • The button and control pads pop out together with a gentle push.
  10. iPod Shuffle 4th Generation Teardown: 10 단계, 이미지 1개 중 1개
    • The control pad comes out of the front case without any additional trouble.
    what is the size of the control pad?
    arvin de castro - 답글
    Based on my measurements on my own device, the diameter of the control pad is pretty much dead on 2.5cm.
    Mitchal Fej -
  11. iPod Shuffle 4th Generation Teardown: 11 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 11 단계, 이미지 2개 중 2개
    • With a listed capacity of .19 Whr, this small 3.7V lithium-ion battery pumps out 15 hours of audio playback.
    • To calculate the capacity in amp-hours, we know P(power) = I(amps)*V(volts), so I = P/V. That yields a capacity of about .051 amp-hours, or 51 mAh. To say the least, that's diminutive in the world of batteries.
    • It's remarkable how long a battery lasts when it doesn't have to power a backlight.
    (Very late, I know..) I wonder if Apple could have fit a movement-based “energy scavenging” device that could have managed to charge the battery enough to run it (almost) indefinitely (say if you only run it an average of 2-3 hours a day, and carry it around everywhere)?
    jimwitte - 답글
  12. iPod Shuffle 4th Generation Teardown: 12 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 12 단계, 이미지 2개 중 2개
    • APPLE 338S0860 C0AN1021 TWN
    • 339S0128 / K9GA608U0E BC80 / FDEF26QV 1025 / 8443 ARM / N2N63MQ1 1031
    • Unsurprisingly, the date codes on this package indicate die manufacture dates in late June (1025) and early August 2010 (1031).
    • "K9GA6" indicates Samsung 16Gb flash, unlike the Nano and touch which use Toshiba flash.
    From the photo it looks like the big chip on back is marked "8443 ARN", not "8443 ARM" ... I'd guess that it's the Flash, and the (much smaller) chip on the other side is the (probably ARM-based) controller.
    Wim - 답글
    Interesting: there's a blank space for an IC that's not present. I wonder what could go there? (Or maybe it's for a connector?)
    cityzen - 답글
    Wouldn't it be 2gb instead of 16gb, since the shuffle is only offered with 2gb.
    Shawn Parker - 답글
    Those are bits, not bytes.
    Andrew Bookholt -
    Which one of these chips handles the D/A conversion and audio output? I'd like to know so that I might compare it to the iPod Nano and touch.
    threebkk - 답글
    Where part of it holds the memory??
    Christian - 답글
  13. iPod Shuffle 4th Generation Teardown: 13 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Teardown: 13 단계, 이미지 2개 중 2개
    • iPod Shuffle 4th Generation Repairability: 2 out of 10 (10 is easiest to repair)
    • Good: The control pad is attached to the logic board via a connector, allowing it to be easily separated.
    • Good: The lack of a screen eliminates a large weak point of other devices, making the Shuffle more resilient to falls. Just don't flush it down the toilet.
    • Bad: You essentially have to break it to open it.
    • Bad: The battery is soldered to the logic board, making replacement that much more difficult.
    • Bad: Apple keeps shrinking connectors. These super-small cable connectors are increasingly difficult to open without breaking them.
댓글 7개
That guy stratched PCB, broke edge of a chip and totally wrench one capatitor. Seen on step 12. Thanks for HQ photos. I wish more patience to author, next time...
quido speedy - 답글
Thank you very much. The guide is very good and I was able to change the battery of my ipod shuffle. It is working again.
Helena Matias - 답글
Hey,
do you mind sharing where you got your battery .. and how much it cost .. ? I’m curious to see how stuff changed in 7 years.
Mine’s still doing ok (bought 2011, used extremely often), but … it’s showing its age.
Thanks ✌️
Darie H -
Btw, u don't need a spludge to open up the outer casing for step 4.
U just wedge the clip with something thin, and it creates a weak point on the casing so u get another person with a thin wedge to use that weak point to open it up.
Mark Hong - 답글
How difficult is it to play any streaming media passing through ipod shuffle or ipod nano hardware
Ankit Anurag - 답글
Very hard. Headphones plug into the jack (duh). So does the charger (iPhone 7/7 Plus CONFIRMED)
FoxRunTime -
what about putting it back together
Hunter Suchowski - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 68
지난 30일: 351
전체 시간: 261,155
