주요 콘텐츠로 건너뛰기
목차
페이지 토막글
This wiki page is a stub. Help us improve this page by adding information to it!
Return to CygoLite Device Page
Light will not turn on
You flip the switch and the light does not turn on
Dead/bad battery
Before opening the device, try plugging the light into the charger (and be sure the charger is not the problem). If the light does not respond to being plugged in, you may need to obtain a replacement battery.
Burnt out light bulbs
After checking if the battery is charged, replace the light bulbs if they are burnt out using the
light bulb installation guide.
Light is dim
Cracked reflectors
See bulb installation guide.
Low battery
Plug the light into the charger and let it charge the device overnight.
Cannot secure to bicycle
Faulty bike mount
If the bike mount will not attach the light to the bike, see bicycle mount installation guide to replace it.
작성자
3다른 기여자 명과 함께
Kelly
회원 가입일: 10/22/12
131 평판
안내서 1개를 작성함
Clemson, Team 14-3, Benson Fall 2012 Clemson, Team 14-3, Benson Fall 2012 회원
CLEM-BENSON-F12S14G3
4 회원들
안내서 5개를 작성함
댓글 한 개
What type of fuse goes into the 6 volt battery, model number NTRVR - WB, it has a 7.5 fuse in it right now
christiansentroy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,118
