주요 콘텐츠로 건너뛰기
목차
학생-기여 위키
자사 교육 프로그램의 멋진 학생들이 이 위키를 만들었습니다.
Battery Is Not Working Correctly
Won’t Connect
Clean battery with compressed air
Clean contacts with rubbing alcohol
If it does not work replace battery module
Over-Heating
Place in a clear air-tight bag/ container and place in refrigerator
If it continues to overheat replace battery module or replace fan
Not Charging
Check to see if charger is seated properly in the port
             Check the charger and port for dust, dirt, or debris
             Clean with compressed air (if still clogged try to use a small amount of rubbing alcohol on a Q-tip)
Not Installing
             Check clips to make sure they are properly set before attempting to place the battery module
Optical Drive (DVD) Is Not Responding Or Reading
Not Opening
            Check to see if there is an adhesive or other method of blocking the access and remove
Not Playing Disk
             Clean with compressed air on both holder and reader
             Clean disk with a microfiber cloth or compressed air
Can’t Access Memory
              Open back cover by removing screw and lifting off
              Check all 4 connections for memory
              Try removing all connections and clean with compressed air
Computer Shuts Down Occasionally When Running
Overheating
   Let computer cool or cool battery as suggested in (Battery Overheat)
Malfunctioning Fan
              Clean with compressed air to remove all debris
Faulty Power Supply
              Plug in the laptop if the charging light does not turn on replace the charger
              If the light turns on, replace the battery
Computer Becomes Unresponsive While In Use
USB Issue
              Are there USB devices attached, such as USB driven devices or thumb drives?                                              Try turning off USB Selective Suspend
                                                Go into Power Options settings.
                                                Right click on the battery icon and select Power Options
                                                Click on "Change advanced power settings"
                                                Select maximize the option USB settings
                                                Then USB selective suspend and disable
Malfunctioning RAM
              Make sure RAM is correctly installed. If it does not work when installed correctly, then remove the RAM and replace it.
Overheating
 The GPU Overheats
Overheating
              Use a can of compressed air to clear the dust off the GPU fans and vents
              Think about upgrading the driver to the current version
              New drivers can be found on the manufacturer’s website
              New drivers can also be found online by searching based off the model number
Debris In Air Vents
There may be dust or debris in the fans or vents on the machine. Spray the area of the vent with a can of compressed air to clean the area.
작성자
2다른 기여자 명과 함께
Connor Brady
회원 가입일: 03/21/19
51 평판
안내서 0개를 작성함
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 UMass Dartmouth, Team S2-G1, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G1
4 회원들
안내서 21개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 423
