주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
15인치 "데스크 램프" iMac G4 700MHz M6498 PowerMac 4,2
Where is PMU reset button?
Computer will not turn on, tried shift/option/command, doesn't work. was told to try to reset the PMU on logic board.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
Disconnect the power cord.
Remove the user access panel from the bottom of the computer.
Press the PMU reset switch once on the bottom side of the logic board. Do NOT press the PMU reset switch a second time because it could crash the PMU chip.
The switch is near the memory slot, next to the airport card.
Wait ten seconds before you connect the power cord and keep your fingers crossed.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi
I tried this. Took off bottom round panel exposing airport card and memory card. Did not see any switch or button. There is just a solid metal panel around the exposed cards, can't see underside of circuit board. Removed 4 screws that allowed me to lift off the dome top but can only see top of circuit board not underside. What to do next?
의
댓글 달기
가장 유용한 답변
Here’s the PMU button:
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The PMU button is under the semi-transparent film layer to the side of the wireless card. It’s almost in the corner of the whole rectangular area. However, this didn’t work for me anyway…….
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Did anybody ever figure this one out?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
paula 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 59
전체 시간: 10,201
