주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2006년 11월 북미에서 출시된 Wii는 닌텐도의 첫 가정용 게임기로, 온라인 게임과 Wii Shop Channel을 통한 게임 및 미디어 애플리케이션의 디지털 배포를 모두 지원하여 직접적인 인터넷 연결 기능을 제공했습니다.
Wii Click of death.
My Wii is a few years old and has decided to CoD (Click of Death) http://en.wikipedia.org/wiki/Click_of_de... any time ANY disk (GC or Wii) is inserted. it still spins. but won't read. this did not happen suddenly. at first it would not read certain disks sometimes, then it wouldn't read most disks sometimes, then it wouldn't read any disk, and now, it wont read the disk and brings up the Wii's BlSoD (Black Screen of Death). Is the disk drive repairable or is it time to swap disk drives or is the Wii cooked with a side of mashed potatoes?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
laz is not dirty, i think it's time to set the dinner table...
의 공유
댓글 달기
답변 5개
가장 유용한 답변
Superchu, sounds like the laser is either dirty, may want to try to clean it, or "cooked with a side of mashed potatoes" . Most likely it is time to replace the drive.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
You can pick up a replacement drive on Ebay for about $20-25 dollars. Fairly easy to do yourself as long as you have a tri-wing screwdriver also found on ebay cheaply.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Superchu did you figure out what it was by any chance? My Wii is clicking too and everytime I put a disk in it try's to read and then a page pops up saying eject the disk and restart the Wii and check the manual troubleshoot guide. So if it was just the lazer that is awesome but if it is the disk drive it would be nice to know so I can just get it out of the way. My 6 yr old wants on there badly and I feel bad not having it fixed yet. Thank you for any help you can give!!!!!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Mine is doing this same thing....... what was the conclusion?
의 공유
댓글 달기
Ordering new drive for mine
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this same problem. First time it happened, I replaced the entire drive. Then it happened AGAIN, but this time I noticed that one of the little helical gears had split and detached from its shaft. Someone kindly posted a ctb file of the gear, so now I'm trying to 1) convert the file to stl or something more common and 2) find a 3D resin printing service who would make 2 or 3 of these for me.
https://www.reddit.com/r/consolerepair/c...
I'll also be adding a screw to hold the shaft in place, as mentioned in this post.
https://github.com/BiegunskiEr/Wii-Disc-...
Replacing a tiny piece feels so much better than replacing the entire drive.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Superchu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 36
지난 30일: 163
전체 시간: 20,901
