주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
laptop says plugged in but not charging.
This problem started 3 months ago, all I had to do was unplug it and then plug it back in and it would charge fine. Now nothing works it just says "pluged in (not charging)" now.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
Use this : Dell AC Adapter LA90PM130
댓글 달기
답변 2개
선택된 해법
This could be an indication that the battery wont hold a charge. Might need to replace the battery
이 답변이 도움이 되었나요?
점수 0
댓글 달기
향후 수리를 위한 준비
모두 쇼핑하기
It seems like you battery is expired because usually laptop`s battery last for 1 to 2 in normal form. So if your laptop is a year or two older then you would defiantly need to replace the batter and make sure to order the proper OEM replacement battery because other aftermarket ones wont give you very good output.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I was change a battery last week but still plugged in not charging
댓글 달기
답변을 추가하세요
Andy Lamb 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 1,671
