주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
20 질문 전체 보기
Screen comes on but does not light up.
I have a PowerBook G4 Aluminum 17" 1-1.67 GHz and it was working fine. All of the sudden the screen comes on but does not light up. I was told that it was probably an inverter board, so I bought a replacement. After a 6 hour tear down and reconstruction it does the same thing. All wires are connected and tight. Any help or ideas would be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
It's a widespread myth that the inverter is the problem in these situations (spread mostly by people who have never done a laptop repair), and 99% of the time it's actually the inverter cable, or the screen itself. With MacBooks and PowerBooks it typically ends up being the screen, however you might want to replace the inverter cable first, since it's a relatively cheap part and there is a chance it's the culprit.
Also, before you start spending money on parts, you'll want to connect the laptop to an external display. If that works fine, you'll have ruled out the logic board as part of the problem, whereas if the external display doesn't work, it's possible you've got a video chip issue.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Agreed +
댓글 달기
답변을 추가하세요
mrclark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 761
