주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 외장 광학 드라이브는 기본적으로 MacBook Air SuperDrive의 리브랜딩입니다.
How do I open the casing?
I have this external disc drive. There is a CD or DVD in it that wont eject. I hear it trying to catch the cd/dvd, yet I don't hear the spinning sound. Is there any way I can open the casing? I don't see any screws on t at all...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
선택된 해법
Steven, take a look at this guide.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
use a big suction cup to lift the bottom plate up so you will not damage the casing. this is what the official apple service manual says
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Without the suction cup, there are three simple snap tabs on either side of the case which can be pushed back with playing cards to open the case. You then need a Torx 10 and Phillips #00 or #000 drivers to remove three screws which hold down the drive in the case. After pivoting the drive up, you need to remove the two side Torx screws that fasten a mounting plate and 4 small Phillips screws to lift up the top plate and remove the stuck disk.
I was going to grant access to the paperclip eject hole I expected to find, but THERE IS NONE! If software won’t eject a disk in this drive, there is no option but DISASSEMBLY!
Jim
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you very much
의 공유
댓글 달기
답변을 추가하세요
steven 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 97
전체 시간: 13,456
