주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
질문 마감됨
Need help on troubleshooting
I was wondering if anyone knows if it is possible to test a logic board for function without installing it back into the frame? I have a board pulled and am working on, and I was wondering what I would need to make it function without having to reinstall it over and over. The Lcd/Digi, Battery, dock and power button flex. Does it need the frame for the grounding?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
I believe it does. you should put it back in the frame for testing.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
nope. You can totally test it outside of the frame. Solder a lead to the bat + and - pins and attach to alligator clips to a DC power supply. You can use powerflex to power on, then disconnect and take readings on both sides of the board. I'm doing it right now :)
jessa
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
What should the DC supply be rated to? I assume a 9V will have different results than a car battery.
I mean a benchtop variable DC power supply specifically used for troubleshooting electronics. Pick one up for $100. You can use it for all sorts of things--charging dead batteries, pushing current into phones with a short to allow the heat buildup to show you where the short is, and doing what you're doing here--testing a phone without using a battery.
You would give the phone exactly 3.8 V---9V or 12V would kill it.
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 139
