주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
20 질문 전체 보기
Internal keyboard and trackpad intermittently not working
Sometimes on boot up trackpad and keyboard will not work although a remote mouse plugged into USB port works ok but the keyboard still does not work.
If unit dropped about 3 inches on carpet (naughty i know ) works again, although sometimes stops working again whilst in use.
I suspect a loose cable/plug. Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
trackpad socket on logic board broken away from soldered joints
댓글 달기
답변 1개
선택된 해법
Yep, if you drop it and it works then a cable will be loose. Basically, make sure all the connections to the logic board featured in this guide are in properly.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
found trackpad socket had broken away from logic board on soldered joints
댓글 달기
답변을 추가하세요
Petethefish 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 3,303
