주요 콘텐츠로 건너뛰기
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
Line of laptop computers aimed at the small business market, designed to replace the Dimension line of laptop computers.
20 질문 전체 보기
laptop does not turn on
My laptop does not turn on. Whether it is used with battery or with cord, the laptop does not start.
Do you have any suggestion which laptop's component does not work? Or maybe how to verify if the laptop receives electricity or not?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Have you checked to make sure that your AC adapter works? If it does, you will have to check to see if the dc jack gets power, for that you will have to disassemble your computer. Use a multimeter on the DC adapter and see if it gets power. If it does, check the on/off switch with a multimeter and see if it has continuity when you activate the switch. What model Vostro is it?
Thank you for answer. It is a Dell Vostro A860 (it is an old model). I can say that the laptop receives electricity because while the cord is pluuged, a blue light is on. Maybe I will have to ask for a service, because I believe that the motherboard is dead. It can be a cause.
This is most likely a bios related issue
disconnect your cord
remove your battery
remove the back top panel to expose the coin-cell battery
remove the battery, wait 15 seconds, then reinsert it
connect your power cord
press the power button
your laptop should turn on
reset your bios configurations
apply any bios and any critical updates
NOTE: you may need to repeat all of these steps depending how many updates
This should resolve your issue. Hope this helps
댓글 달기
답변 3개
선택된 해법
Dan, try this first:
1. Remove the battery and power supply.
2. Hold the power button down for 30-45 seconds
3. Release the power button
4. Put the battery back in and plug in power supply
5. Push the power button and it should power up.
Let us know what happened. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
But why this happens?
댓글 달기
maybe the ic of power or other thing in mother board.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
this is most likely a bios related issue
disconnect the power cord
remove your battery
hold the power button down for 20 seconds
remove the back panel and locate the coin-cell battery which should be in upper left hand corner
remove the battery
wait 15 seconds then reinsert the coin-cell battery
rest your laptop settings
log into your laptop
check for bios and critical updates and install them
restart your laptop
NOTE: There may be multiple bios updates which need to be applied thus don’t be surprised if you need to repeat these steps a few times
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 5,797
