주요 콘텐츠로 건너뛰기
A Type 5491 shaver by Braun with many similarities to the models 7570, 7564, 7664, and 7690.
1 질문 전체 보기
cannot get it to turn off
it has 3 options to operate . it will operate on all 33 but will not come down to off
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
This might help: Braun Shaver Model 7680 Battery Replacement
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Open the case as per tutorial to change the battery. I had similar issue but just not turning on, case was full of hair which prevented the correct operation.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The slider switch on mine has failed too. It jams in one or two 'up' positions that make no difference. Mine is the Braun 7505, but essentially the same as many others. YouTube has one video on the topic, solving the problem with a hammer. Unhelpful. :-/
Anyone tackled the sliding switch problem? Certainly not a battery issue.
Thx.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@ardwych see if this gets you to where you need to be with that switch.
댓글 달기
답변을 추가하세요
Harry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 6,969
