주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 9월 출시. 디스플레이 - 800 x 1280 픽셀, 9.4인치. 칩셋 - 1GHz Nvidia Tegra. 5MP 카메라. Android 운영 체제, v3.1(Honeycomb), v4.0.3(Ice Cream Sandwich)으로 업그레이드 가능
WIFI does not work
Hi,
I can't connect to the wifi at home, it detects the signal but it does not connect to it. It thought it was my wifi's home, but at work it happens the same. I also went to another person's house and the wifi does not work.
I put the password again, disconnect and connect the wifi, but nothing happened.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
polharder, has it ever worked for you? Did you change anything in your settings lately
의 공유
댓글 달기
답변 1개
선택된 해법
Try going to an open WiFi location (an AP without any security password). See if it can connect to it (altering your AP settings; going to McDonalds or Starbucks Coffee house etc...)
If it does work then you'll need to check the case of the password as upper & lower case are different here (even unicode characters). Also make sure the password is not overly long as some devices can't parse the key longer that 10 digits/characters.
Next check what security option you are using on the AP and make sure your device can do it. As an example some older devices can't to WPA 2.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
polharder 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 45
전체 시간: 606
