주요 콘텐츠로 건너뛰기
Laptops manufactured by Dynabook (formerly Toshiba). Toshiba has since transferred 100% ownership of the laptop business to Sharp.
Not working will not power up
I have the Toshiba C55t-A5218.
I couldnt get windows to come up, but later did.
However when the laptop was doing a restart, it died and now it wont power up at all (with adapter or battery.
Any suggestions? The power adapter is producing 19 volts. I have also completed an ohm test on the power adapter cable in the laptop, all is well there. It wont power up with the battery plugged in. But I am uncertain if the battery is charged.
Also removed the memory and still same results. Please help, or I have a boat anchor.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 6개
Toshiba offers a nice support page: SATELLITE C55T-A5218 SUPPORT
I tried another power adapter and it worked perfectly. So i ordered a new one and was even able to install WIN 10 on it and sold it to a person.
Hey thats GRAET !
The laptop is working aging :)
thank u Darren !
I have no power at all. The laptop will not boot, nor does any indicator LED come on showing power is present. There is a good DC voltage at the power cord. The 3V battery cell is good, but I replaced it anyway in case I was only reading a surface charge. I disassembled the laptop and checked the main board fuse; it was good.
I have installed a new 10.8V main battery with no luck. I did remove the power cord and battery, held the power button down for 45 seconds, and then tried each of the power supplies; again with no luck. I suspect a bad power circuit on the motherboard. If that is true then the computer has turned into a brick.
@Tsvika Damri Thank you
댓글 1개 더보기
댓글 달기
답변 3개
선택된 해법
Darren, start by performing the following steps:
-Remove the battery and Power adapter
-Press and hold the power button for 30-45 seconds (with battery and power still removed)
-Insert just the battery and attempt to boot the laptop.
-Insert just the power adapter and attempt to boot the laptop.
If you have more than one memory module, remove one module and try booting with just one module installed.
The other thing I would try is to replace the power cord. Toshiba's are known to blink 5 times with a bad power cord.
이 답변이 도움이 되었나요?
점수 3
댓글 9개:
I checked the power cord from outlet to adapter and from adapter to laptop. Produced 19 volts, would the cord still be bad or cause it to blink?
in theory no, in practice anything is possible.:)
Ok cool, will try it
5 blinks, bad battery.
I have to say thank you for this answer. Tried it and it worked first try. You are a life saver!
댓글 4개 더보기
댓글 달기
Hard to tell here whats happening.
Try disconnecting the HD to see if that allow the system to startup (as far as it will without a HD).
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
HD removed and still same response. Plus when the battery is connected and i press the power button, the power light flashes 5 times and quits.If the power adapter is connected by itself no flashes and no activity.
댓글 달기
i have the same problem i think maybe CPU is gone, even tho its hardly used!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
only starts with no ram
댓글 달기
답변을 추가하세요
Darren 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 45,775
