주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix L810은 포인트 앤 슛 기능과 장거리 줌, 동영상 촬영을 지원하는 합리적인 가격의 콤팩트 디지털 카메라입니다. Nikon의 L 시리즈 중 하나로 2012년 초에 출시되었습니다.
How do I fix the lens cap error?
There is a lens cap error asking to remove the lens cap even though the it is already off.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 14
댓글 2개
My lens is locked in the fully extended position, I also get the lens cap error.
의
mine is in the full zoom position and I get the lens cap error is there any way of fixing it?
의
댓글 달기
답변 5개
가장 유용한 답변
My camera got stuck on “turn off, remove lens cap.” Error mode, so i tried the forcibly hitting camera by dropping it to carpet floor about 2-3 times (soft surface) and immediately removed error! Thanks!
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I had the same problem, so what I did was to tap he side of the camera couple of times and switch on the camera. It might not work first time, but it cleared the error message
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you Robert! I placed a book on a countertop and hit the camera forcibly against the book approximately 20 times and it worked eventually. I tired to hit all sides of the camera. It cleared the error message. All fixed now!
의
댓글 달기
Here are some possible ways to fix this problem based off of relevant researches,
1) There could be some dirt, sand, or small materials blocking the way for the lens to extend so you would need to take a microfiber cloth and clean as much as possible around the lends barrel. Another way could be to forcibly blow out any obstructions around the lens barrel.
2) Turn the power off remove batteries and wait one minute then replace the batteries with a brand new set, once this is complete turn the camera back on while holding the functions button (the ok button). Should that not work turn camera back off and remove memory card and repeat the process.
3) Plug in the AV (audio/video) cable, the reason so is because this will provide more power for the camera lens to extend and refocus
4) Placing the camera on a hard surface, face the lens towards the ceiling, and hold the shutter button while you press the power button. The idea for this process is to try realigning the lens back into their personal slots.
For more information click here to Refer to the troubleshooting page.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks. That worked for me
의
댓글 달기
This is probably the cause of stability. But it is best to replace the lens.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The best and most logical solution I have found online was to clean the lens sensor.
The lens sensor is located around the casing of the lens that potrudes when the camera is activated.
Using a soft cloth with some isopropyl alcohol, or blowing around the edge usually solves the problem.
이미지
Please enlarge the picture to see the arrow pointing to the lens sensor location.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bo Cheng 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 36
전체 시간: 22,305
