주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 다목적 Android 태블릿은 2013년 5월에 출시되었습니다. 7인치 800x480 LCD 화면, 듀얼 코어 프로세서가 탑재되어 있으며 최대 32GB의 추가 메모리를 지원합니다.
Why does my device keep shutting down?
I've had my tablet for a few months now and recently after being used for a while, it randomly shuts down. When this happens it usually won't come on for another couple of minutes and then simply repeats the process. Any help would be appreciated!
Update (08/04/2018)
My tablets gets to the @9 dualcore screen then stops and shuts off and its a stealth g2 tablet
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
의
I would like to return it back for it to be repaired. Would like a mailing address.
의
I have a triosmile 10 in elite tablet. It takes for ever to download apps. Then once it does the apps don't open then it freezes up and shuts down. Then takes several minutes to restart. I received as a gift. What can I do to fix problem. I have reset and reset back to factory but it still does the same thing
의
@lindatw
ifixit does not sell your tablet or do repairs to any equipment or devices.
I suggest that you contact the retailer from where you got it or check what it says in the user manual about how to contact the manufacturer when you have problems with products that are still under warranty.
의
댓글 달기
답변 2개
가장 유용한 답변
The most common reason for this to occur is because the battery is done. The life of a battery was never designed to last for a long time, so there is a high chance that the battery needs to be replaced. A guide to the replacement of the battery can be found here.
This could also be related to another problem with the device.
Be sure to check out the Troubleshooting page for more information.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I get a lot of about Why does my device keep shutting down. And thanks for sharing useful information. ''https://procana.com/
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Antoninus Lamptey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 16
전체 시간: 2,090
