주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for laptops manufactured by ASUS.
20 질문 전체 보기
Windows 10 HDMI Connection Intel Graphics Issue
Hey,
I have updated to windows 10 from 7 and I am having the next issue:
When I connect my HDMI cabble to the computer,
the Notebook doesn't recognize the 2nd screen(TV)
I noticed the issue occurs because of the Intel driver.
When I Uninstall "Intel(R) HD Graphics 3000",
The Notebook recognizes the 2nd screen using Nvidia GeForce Driver.
Enviorment Information:
Notebook: Asus N55SF
Operation System: Windows 10
Display adapters: "Gefore GT 555M" & "Intel(R) HD Graphics 3000"
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 16
댓글 6개
you just need to update the graphics driver visit asus http://goo.gl/vB0wbJ and see if that solves the issue .
The above link from Gabriel is *NOT* the official ASUS tech site. I would check Asus' site first for any updates. The link above appears to be a generic PC repair/support service (i.e., they will charge you $$$$).
IOBit's freeware Driver Booster works really well for updating drivers.
I have tried everything suggested above and no luck! Any more suggestions. I have an Asus UL50 VT
Don K.
Hi Alls
My Laptop model is 'VAIO VPCZ11MGX/X' since updated to WIN 10 ,64 bit , have the same problem for using HDMI connection .
Please note using the your trick (Disable & Enable device on the Intel (R) HD Graphic ) but still not working .
My Graphic Processor is NVIDIA GeForce GT330M GPU and mobile intel Graphics Media Accelerator HD with total Available Graphic Memory :2560MB.
Please consider when installed NVIDIA driver for WIN 10- 64 bit , driver will send a message which not compatible hardware !!
and in the final on the device manager -Display adaptor only see an Microsoft Basic Display Adaptor with yellow attention sign .
Thanks in advance for any help and advice ...
댓글 1개 더보기
댓글 달기
답변 11개
가장 유용한 답변
Hi there!
Sorry for my english in advance,
I searched a lot for a solution since i suffered from the same issue,
nothing helped but with some experiments the following simple steps solved my problem (intel hd 3000 on 2nd gen which they say is not supported any more):
1. Connect the HDMI cable to the TV.
2. Device Manager-> Display adapters
3. Right click on "Intel(R) HD Graphics xxxx" (Your graphic card) and disable.
4. Right click again and enable.
Thats it! don't be skeptic (-:
after trying too many drivers unsuccessfully, i was suprised how simple was that.
Note: You need to repeat those steps everytime you connect your laptop to the TV
이 답변이 도움이 되었나요?
점수 20
댓글 18개:
Miraculous! I'll come back if it needs to be done more than once!
I swear you are my god :'D !!
I've been searching for a fix for this issue for countless hours (or at least since windows 10 last annoying update -not that any of them isn't annoying- ) and was sadly coming to a dead point (upgraded and downgraded the drivers, adjusted display's resolution and settings, changed the cable, turned things on and off a million times and even tried the cable and tv on a different laptop -where they worked with no trouble-)
I was really giving up and then suddenly this worked like magic!
Thank you sooooo much ! <3
when u disable the driver screen goes black how can i click enable again when i cant see xD
Thank you for saving me from pulling my hair out, the world needs more people like you!
I'm glad I was able to help you guys.
omniscar13,
When you're disabling your display adapter the system switches to the generic windows driver which has awful resolution but yet it is good enough to let you enable your display adapter.
First check if your intel hd drivers are installed properly then follow my instructions.
댓글 13개 더보기
댓글 달기
i had similar problems.
there are a couple of brands who have problems with windows 10 ( from win 7 to 10 )
did you tried to instal the newest drivers of intel hd graphics from the servers from intel?
try that and let us know
good luck
kind regards
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hey Rafi,
for me it was about uninstalling the card and then finding the good driver. I tried many so cannot point for a particular solution, but here are my steps (accessed my devices using devmgmt.msc in the Run command):
  • I uninstalled (right-click -> uninstall) the Intel HD card.
  • I downloaded and ran Intel's Driver Update Utility.
  • I tried many many different drivers that I could find on Intel's Download Center, the one that worked for me is `win64_153338.exe`, that you can find here. You might also want to try this one.
Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I had the same issue with the same Graphics card. After a few days of trial and error. Here's what worked for me.
Power off your laptop and keep it unplugged
Take out the battery
Hold the power button down for about 20 seconds
Plug back in the wall and/or put battery back in
Plug in the Hdmi to your laptop
Power on your computer
Your computer from this point may search and find the driver to run the Hdmi , mine did. Hope it works for you.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks god I saw your answer!!!! I had tried what they suggested above but nothing help TT~TT.. Thank you so much for your kindness
댓글 달기
Just to reply to my previous comment above I have found a successful working solution to this problem. The problem was in trying to update to the latest Intel graphics driver. The fix was to go to my laptops model number drivers repository (for example A54C and install the driver from there.
for example VGA driver from.
https://www.asus.com/support/Download/3/...
Also suggest to update BIOS. This has fixed all the issues I had been having around 2-3 months.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
After months of the issue I finally solved this problem. You cannot turn the PC on then turn the TV on. It wont work. First thing you have to do is turn TV on. Wait til its on THEN turn PC on. Works every time now.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Download and run “Display Driver Uninstaller “
from either:
https://www.majorgeeks.com/files/details...
or
https://www.wagnardsoft.com/
Important to read and follow instructions!!!
This program removes all traces of previous drivers, which is where the minor glitches usually reside. It gives you a fresh start, like a fresh re-install of Windows, if you like.
You will then boot-up and see MS’s generic graphics driver “Basic Display Adaptor” in Device manger.
Install the latest driver for your graphics adapter.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Just to let every know I have been having the same problem when connected laptop to TV. The only thing that has worked is Device Manager, right click Intel 300 etc and put disable, then enable. It is so silly but at least it works.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Another tip. My TV is a Samsung 50inch and it has an issue with HDMI power down. A solution is to turn TV off (from mains) and turn laptop off. Turn TV on, go to HDMI where you have connected to laptop.
Now turn on PC connected to TV with HDMI and that should solve most problems other than graphic driver.
댓글 달기
sterownik HDMI sterownik
https://support.amd.com/en-us/download
이 답변이 도움이 되었나요?
점수 0
댓글 달기
on my msi laptop, I have the same problem and I have to play with the intel virtualization technology and the VT-D on bios, keep disabling and enabling to hdmi works again until it stop working again, especially with the updates (windows and GPU). Try to see if can work with u. Good Luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I’d like to add how I resolved this issue because for me none of the above actions worked.
My older netbook is Asus X201E (with Windows 10) - HDMI connected to Samsung 27 Inch monitor.
Surprisingly, this finally worked (should have tried first): Desktop right click - Graphics Options - Output to - Digital Television (select)
(After that, many more resolutions became available in the Graphics gui, and even bloody Win10 warned that my resolution was not optimal at this point …)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
rafi port 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 32
전체 시간: 100,936
