주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mach Speed Technologies에서 제조한 Trio Stealth G4는 7.85인치 HD 터치 스크린을 탑재한 태블릿입니다. 이 기기는 Wi-Fi, Bluetooth 및 Google Play 기능을 지원하며, 쿼드 코어 프로세서와 전면 및 후면 카메라를 포함한 사양을 갖추고 있습니다.
How do I reset my password?
I forgot my password and can't get into my tablet. How can I reset it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 9개
One of them told me to go to my setting or widgets but HOW WHEN I CANT LOGIN
의
Power volume + only resets it. Still asks for password. Help please.
의
Yea how wen it asksnfor password to do anything.
의
there are many ways, hope it can help you:https://www.isunshare.com/windows-10-pas...
의
Hi @ Elina ANN,
The Trio Stealth G4 is an Android tablet, not a Windows tablet.
의
댓글 4개 더보기
댓글 달기
답변 2개
가장 유용한 답변
Hold down Volume + button and Power button at same time. When screen comes on let go of Power button. When the large Android shows on screen let go of Volume + button. Use Volume – button to scroll to Wipe Data/ Factory Reset.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Will this cause me to lose all my pictures and data? Is there any other way to reset just the password without resetting the entire device?
의
Unfortunately you will loose your data. It is the security design, no point in having a password to protect your information if there is a way around it.
의
I have a used Trio Tablet Mst-1041 and another smaller generic tablet that was given to me because the Passwords were either forgotten or corrupted & I am trying to do a "Hard reset' on both of them also.. When the Power button & Vol+ is used it boots into the normal window asking for PW.. When the Power button & vol- is used it boots into safe mode still wanting a PW. These answers here are not helpful at all, there must be another way to do hard resets on these tablets. Any viable answer will be highly appreciated since I really hate to throw away two perfectly working tablets just because of a stupid Password lockout.
의
댓글 달기
If you have enabled Android Device Manager on your device, you can reset your password from the Device Manager website. Follow these steps:
  • Log in to Android Device Manager
  • Select your device
  • Select 'Lock'
  • Enter a new, temporary password for your device and click 'Lock'
  • Enter the temporary password on your device
  • Go to your lock screen settings and disable the temporary password you created.
If this doesn't work or you do not have Android Device Manager enabled, you will probably have to do a factory reset. Follow kris's instructions or check out the troubleshooting guide.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How can you "Log" in to the Android Device Manager" when you cant even log in without the "Password" to begin with? The "Issue" is.. The "Question" is... How can you hard reset the Tablet to erase, factory reset or get around the the password requirement. Did you even read the question? Your response was not helpful at all.
의
댓글 달기
답변을 추가하세요
Dani Gutwein 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 7,689
