주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HMDX Jam HX-P230은 2012년 HMDX Company에서 제조 및 출시한 무선 블루투스 스피커입니다. JAM 클래식 휴대용 스피커로도 알려져 있습니다.
will not pair with iPhone
will not pair with I phone only pairs with ipad
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
Where is the reset button? Please
의
Hi @ paulagunn,
Try pressing the Play/Pause button for 5 seconds.
의
Will my hmdx 240 earbuds works with an android device
의
댓글 달기
답변 4개
선택된 해법
Hi,
Found this info in the link below, hopefully it is relevant to your problem:
http://www.jamaudio.com/jam-classic-wire... (scroll down to reviewer post 05/02/15)
''If you ever come across having issues with the speaker not pairing, and not showing up on the bluetooth devices list in your tablet/phone, do this. It worked for me:
1. Turn on speaker.
2. Press reset button.
3. Turn on again.
4. Press simultaneously the "PLAY" and the "+" buttons, until the blue light blinks faster (2-3 timer per second).
5. At this moment, the speaker should show up on your tablet/phone pairing list.
6. Pair the speaker. And you're set to go!''
Also another reviewer said to ensure that you should turn off one of your devices when you try to pair with the other as he found that it confused the speaker when both were on. (post on p.4 dated 12/03/14)
이 답변이 도움이 되었나요?
점수 18
댓글 25개:
I found this information very helpful
의
Thank you. Worked for me on my Samsung.
의
The Jam2 instructions don't tell you you must hold the play button and the "+" button simultaneously to enter discovery mode so that the iphone will see the device
의
Thanks!! For so long I've been unable to use this speaker. Almost pitched it. Worked perfectly.
의
Really nice advice.
의
댓글 20개 더보기
댓글 달기
This solution WORKED for me.
I have: iPhone 7S and Jam Plus HX-P240 (3 yrs old, circa 2015)
My iPhone showed Jam speaker but showed "connection unsuccessful" when I tried to pair. I tried several fixes including resetting the speaker. Nothing worked until I followed the chosen suggestion.
1) Turned Jam Plus speaker OFF.
1) In iPhone bluetooth settings selected Jam Plus, hit the little "i" button & selected "Forget this device".
2) Turned Bluetooth OFF on iPhone
3) Turned JamPlus ON and held down the power button AND "+" button (I did this with left hand - I'm right-handed - this left right hand free to do step #4).
4) Simultaneously in iPhone settings, turned Bluetooth ON (still holding down the speaker power and + buttons).
5) iPhone discovered the Jam right away. I selected it & it connected!
NOTE:
To test I turned both off several times & each time it connected JUST BY TURNING ON. I did NOT need to hit the "+" again.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Well telling my iPhone Bluetooth to “Forget My Device” really messed it up. Now I cannot get my JAM Classic to connect at all.
의
댓글 달기
Hi @Joanne Brandon,
Yes it will.
Bluetooth is a universal system so it should work with any device that has BT capability.
Sometimes there may be compatibility issues between two individual BT devices but in essence it will mostly work OK.
Here’s a link to the user manual which may help in setting it up.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Switch the speaker selector button below the speaker to “mono” worked for me when l was having difficulty pairing the speaker with my iphone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
joey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 24
전체 시간: 67,549
