주요 콘텐츠로 건너뛰기
The TI-30X IIS is a scientific calculator with trigonometric functions first introduced by Texas Instruments in 1993. It uses both a battery and a solar cell for power.
Automatically adds a digit to the end of my entry
My calculator automatically adds a 9 to my last number every time I try to do math. For example, I type 5 + 6 and expect =11, but calculator does 5 + 69 and I get =74 :(
The 9 button does not appear to be sticky.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 달기
답변 6개
가장 유용한 답변
Technical support just helped me fix the same issue. You need to reset the calculator. Press the "2nd" key followed by "0". Arrow down to option 2 "yes". Problem fixed.
이 답변이 도움이 되었나요?
점수 18
댓글 10개:
worked for me ty
This worked for me thanks so much
Mahalo! That worked for me, too.
OMG! I can't believe it was that easy to fix. Thank you very much!
mine kept adding 0.5, and this just fixed it, thanks so much!!
댓글 5개 더보기
댓글 달기
One of my calculators is adding a digit to the end of each entry.
I know how to reset the calculator but when I try, I am unable to arrow over to Y on this screen:
RESET: N Y
I also tried holding down ON and CLEAR at the same time but that is not working to reset the calculator either.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
thank you so much
You are a legend
댓글 달기
shorted PCB keys, try to clean the PCB keys with alcohol (To dismantle, you'll need to apply hot air on the boss around 200°C)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Does anyone know how to do this on purpose?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I’m also curious about how to make this happen on purpose. Thanks for the solution by the way, real life-saver
댓글 달기
0.5 2nd and the arrow
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you notice there is a small k on the bottom right. The constant. Here is information about it and how to set it. I can be used for "good" not "evil" For example: If you are doing a process over and over like # X 2 + 3. You can store the operations as k, then just put in the number and hit =. If you put in a 9 and hit =. It would show 9 X 2 + 3 = 21. Or maybe just X 2. Old calculators, you could hit the = to keep doing the same thing like X 2, X 2, .... This is what the k does.
How do I use the constant K function on the TI-30X IIS/B?
On the TI-30X IIS/B, pressing [2nd] [Division] turns on the constant mode and allows the user to define a constant. K appears in the top of the display when the constant mode is on. The [=] key places the contents of K at the end of the expression in the display.
To enter a constant:
1) Press [2nd] [Division]. If a constant is already stored, press [CLEAR] to clear it.
2) Enter a constant (any set of operations, functions, and values).
3) Press [=] to turn on the constant mode. K appears in the display.
4) Press [CLEAR] to clear the display.
5) Enter an initial value. If a value is not entered, 0 is assumed, and "Ans" will appear in the display.
6) Press [=] to place the contents of K at the end of the expression and evaluate it.
7) Continue pressing [=] to repeat the constant.
The result is stored in "Ans", which is displayed, and the constant is used to evaluate the new expression.
Please see the TI-30X IIS/B guidebooksfor additional information.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Michelle Leonard 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 29
지난 30일: 130
전체 시간: 17,286
