주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Farberware에서 제조한 퍼콜레이터 지원.
My percolator is not heating
My percolator does not heat at all. When I connect it, the water remains cool. The base becomes very hot after some time, but does not heat the water. Does anyone know what is wrong with it, and how to fix it? I have a Farberware millenium percolator, model fcp240.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I have FCP 240-A model that stopped heating. How do you take it apart? The bottom screw comes off easily but the there seems to be a bolt inside the pot that needs to come off. I can get leverage with a wrench. Suggestions?
댓글 달기
답변 3개
가장 유용한 답변
@nadeshko could be a thermostat as well as a heating element issue. time to take it apart and inspect. Take a look at this video for an idea of what to look for. If in doubt take plenty of pictures and post those with your question. Use this guide for that.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If your Farberware percolator is not heating up, there may be an issue with the heating element or thermostat. Check to make sure they are clean and free of any mineral deposits. If they are damaged, they may need to be replaced.
Another possible issue is the power cord. Make sure it is securely plugged in and that the outlet is working. If the power cord is damaged, it may need to be replaced.
For more information kitchenzap.com
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My percolator does not connect to electricity
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@patrobus not enough information here give us more details. What do you mean it does not connect to electricity? Give us more of a description
댓글 달기
답변을 추가하세요
Andrea Garcia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 5,542
