주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Touch wont work after dropped in watter
hello everybody! i have iphone 6.. before 3-4 days it dropped in water (the top of the iphone ) i put it oute quickly i make it dry and after one day iphone open .. but touch wont work.. also i see down on screen some grids you can see the photo i send u
now.. i already order new screen i will change it tomorrow cause i m still on holidays.. but i want ask.. the problem is with lcd & digitizer or its on board? maybe have some water hidden and i must clean better? or if i change the screen it will work fine? thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
thanks for your reply.. i will replace it tomorrow then i already buy one high quality lcd & digitizer A+++ i hope it will be good quality .. i will post the resaults ! thanks again
댓글 달기
답변 2개
선택된 답변
Use this teardown to start your water damage repair.
Then use the Water Damage Guide for how to clean up the phone. Be very careful. The guide really is important because you don't want further corrosion in your phone.
Once everything is taken care of, you will definitely need to replace your screen. Follow this guide for the screen replacement, then another for the home button, and lastly, one for your front camera assembly. The home button, camera, and LCD shield will need to be transferred since they do not come with the new screen. Definitely be careful with the home button as you will lose touch ID if you ever have to replace it.
iPhone 6 LCD and Digitizer 이미지
상품
$69.99
iPhone 6 이미지
안내서
iPhone 6 분해도
난이도:
운영
iPhone 6 Screen 이미지
안내서
iPhone 6 Screen Replacement
난이도:
운영
20 minutes - 1 hour
iPhone 6 전면 카메라 및 센서 케이블 이미지
안내서
iPhone 6 전면 카메라 및 센서 케이블 교체
난이도:
운영
30 minutes - 1 hour
iPhone 6 Home Button 이미지
안내서
iPhone 6 Home Button Replacement
난이도:
운영
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
thanks for your informaton! i will follow all guides
Good luck and keep us posted!
i follow the steps and i replace the screen .. iPhone open normal but touch still wont work. Maybe have damage on board? should i send it to someone who know fix boards?
Do you have a grey bar on the top of the screen?
after i change screen i dont have bar only the touch dont work
댓글 달기
Your screen has water damage and needs to be replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
emted16 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 9
전체 시간: 136
