HP laptop overheats and shuts down.
My HP G72 laptop overheats and turns itself off. What are the possible causes? I have taken it apart and cleaned it completely inside. Very small amount of dirt and the fan is working.
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
좋은 질문입니까?
@vinced when you cleaned it you odf course made sure that all the air inlet vents were clean and un-obstructed. Just because you hear your fan, does not mean it runs efficiently. I would suggest you replace the fan and replace the thermal paste on the heatsink. A lot also depends on where you use your computer. Always make sure that the air vents are not obstructed. So do not use it on something like a pillow or similar.
이 답변이 도움이 되었나요?
Thank you, oldturkey03. Yes, I did check all air vents and all were clear. I used canned air and cleaned every square inch inside the laptop and checked for burn mark or any signs of something "not right", but all looked good. I have been using a cooling tray under the laptop, but it still overheats. Also, I use it on a table top with plenty of clear space around it. I, also suspected the cooling fan and the heatsink were not working properly. I removed the fan/heatsink and cleaned off the old thermal paste and with new paste. But still the same problem. A new fan is less expensive than a new laptop, so I think I will order a new fan/heatsink assy. Thank you for your help. I do appreciate it.
spesso sui modelli g62 e g72 il problema e’ il surriscaldamento della scheda video… a lungo andare il chip si distacca dalla piastra madre e comincia a dare problemi sino al punto che il notebook non si avvia piu’. E’ necessario effettuare il reballing della skeda video
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 2,651
댓글 5개
Blow some compressed air into the fan duct, you"ll be suprised how much dust comes out. it worked for me :).
magnusvir 의
Technician repaired my laptop for the same overheating as I also have a G72, the fan now works but the computer does not. Can anyone help?
david_ogun 의
Can you tell me all the information about the problem?
Jonas A. 의
Does the computer turn on but with a black screen?
Jonas A. 의
Hi Thank you everyone for commenting. I do not have the laptop any more. It would tun on like it normally should and everything would work perfectly for a while, but after some time whether I used it or it sat idle it would just shut down for no reason what so ever. When I took it apart the fan worked fine and was clean because I would blow compressed air into all the open vents and the fan area every month or so. Also I always used the laptop on a hard surface. Thanks again.
Vincent Donatacci 의
