screen black but computer on
Computer is on but screen very dark almost back. Tried to reset P ram & also took out memory cards & then re-inserted. Still black screen. What to do?
좋은 질문 입니까?
좋은 질문 입니까?
Can you still see a faint image on the screen? If yes, try AussieMacs suggestion. If that fails than most probably your inverter board is gone.
Look at this MacBook Core 2 Duo Inverter Replacement.
The inverter controls the backlight of the screen and is cheaper than a new LCD. There is, however, the faint change that the backlight itself failed. Than you do have to replace the LCD.
해당 답변은 도움이 되었습니까?
+ To check this out hook it up to an external monitor.
There is an easy way to handle your problem; maybe you can try the software "tuneup360". My friends and I all use it, which can help you fix all the problems you may encounter.
해당 답변은 도움이 되었습니까?
That's just wonderful if you have a PC. I believe the poster is using a Mac.
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 1,813
