주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
screen black but computer on
Computer is on but screen very dark almost back. Tried to reset P ram & also took out memory cards & then re-inserted. Still black screen. What to do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
Can you still see a faint image on the screen? If yes, try AussieMacs suggestion. If that fails than most probably your inverter board is gone.
Look at this MacBook Core 2 Duo Inverter Replacement.
The inverter controls the backlight of the screen and is cheaper than a new LCD. There is, however, the faint change that the backlight itself failed. Than you do have to replace the LCD.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
+ To check this out hook it up to an external monitor.
댓글 달기
This may sound dumb but have you tried increasing the brightness with the F2 key. otherwise the backlight is dead and you need a new screen here
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
There is an easy way to handle your problem; maybe you can try the software "tuneup360". My friends and I all use it, which can help you fix all the problems you may encounter.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
That's just wonderful if you have a PC. I believe the poster is using a Mac.
댓글 달기
귀하의 답변을 추가하세요
david 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 5
전체 시간: 1,814
