주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Linksys EA9200은 최대 3.2 Gbps의 무선 속도를 제공할 수 있는 트라이밴드 라우터입니다. 모든 네트워크 활동과 요청을 빠르게 처리할 수 있는 1GHz CPU를 탑재하고 있습니다. 4개의 기가비트 이더넷 연결 포트와 2개의 USB 포트(그중 하나는 USB 3.0)를 갖추고 있습니다. 스마트 기기를 위한 Linksys Smart Wi-Fi 애플리케이션과 호환됩니다. 5GHz 대역에서는 높은 데이터 트래픽을, 2.4GHz 대역에서는 낮은 트래픽을 처리합니다.
One external broken antenna
When I was setting up the device one of my antenna broke, Is it possible that the router works like that, or do I need to replace the antenna?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Hi,
Where exactly is it broken?
Has the connector port on the top of the router been broken or just the antenna itself?
If it is the port connector then there may possibly be more damage inside the unit.
If it is just the antenna that has broken and not the connector port, then it depends on which antenna has been affected. I think that there is 1 antenna for the 2.4GHz band and 2 antennae for the 5GHZ band, but I do not know which is which. You will most probably experience connection problems, drop outs, reduced range etc. It may be best to contact Linksys support to get information regarding which antenna has been affected and whether replacements are available. Here is a link http://www.linksys.com/us/support-articl...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It looks like 2 of your antennas are for the 5 GHz operation and the other for standard 2.4 GHz. So depending of which one is broken the router should function normally. If this is a office setting with multiple floors and you are actually using the 5G quite a bit you may experience a smaller coverage area. The 5G will penetrate thicker walls but not go quite as far as the 2G .
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Upgradeable antennas mean you may not have to buy a whole new box to get better Wi-Fi. The antennas should deliver a significant bump in horizontal range, but if you’re having difficulty reaching a wireless client (a smart TV, a streaming box, a laptop, or what have you) on a floor above or below the router, you’d be better off with a power-line range extender or stringing ethernet to a wired access point.If you need right help then connect linksys team by clicking http://www.linksysroutersupport247.com/
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
wendy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 23
전체 시간: 10,437
