주요 콘텐츠로 건너뛰기
A titanium flat iron identified by model number HPK12 and manufactured by Hot Tools.
4 질문 전체 보기
Why is my flat iron getting too hot?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
This could be happening for a number of reasons. First, I would make sure that the temperature control dial is actually changing the temperature of your straightener. If it isn't, I would recommend replacing it. If the temperature is changing, but it just seems hotter than it is supposed to be, I would contact the manufacture to see if they can offer specific specifications in order to test the plates to see if they fall within these specifications. You should visit our troubleshooting guide here for more information.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
"A number of reasons"? Well that's certain a nebulous answer.
댓글 달기
가장 유용한 답변
@tkfrick , Check and see if iron is still under warranty and return as defective for refund,replacement or repair. If your curling iron is getting too hot and the temperature control select switch/thermostat is not controlling the heat setting as it was before, the switch is probably faulty.
Replacement parts are available through the manufacturer's website, beauty supply stores, or online some times. Link to contact hot tools below. Good luck.
http://www.hottools.com/contact-us/
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Student question.
Thanks mayer, I actually had the question answered and found this out, liked my answer better so I left it. Hope you had a good Halloween.
댓글 달기
답변을 추가하세요
Tasha Frick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 25
지난 30일: 41
전체 시간: 6,615
