주요 콘텐츠로 건너뛰기
다운 재킷은 얼어 붙은 온도와 바람으로부터 코어를 단열시켜 부드러운 온기로 감싸줍니다. 그들은 매우 압축성이 있으며, 보온성이 매우 가볍고, 하루 종일 사용하기에 매우 편안합니다.
Zipper gets stuck all the time
Patagonia TorrentShell jacket
Zipper of my Patagonia TorrentShell gets stuck all the time. It stops in neck area when trying to get it closed. Fabric of inner stormflap gets stuck between zipper.
Has anyone tried to sew a some kind of reinforcement to stormflap? Maybe repair tape in flap will prevent it getting between zipper?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
villemitikka - I had this issue too and took my jacket to Patagonia - they ran 5 lines of stitching down the inside flap to stop it from snagging and it's worked perfectlyl. They have a free of charge repair or replace area in their stores.
Hope this helps!
John - Thanks for your answer. Sounds good and easy. Got to try stitching by myself.
댓글 달기
답변 3개
선택된 해법
Here's the guide on zipper repair for the Patagonia:
Installing A Main Zipper In Your Patagonia Down Jacket
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
villemitikka , I do not own this type of jacket, on a jacket that I had, did have this problem, so what I did when zipping up I would use my index finger to keep (guide) inner flap material away in the collar/problem area while zipping up. Worked for me. Good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
try using a old candle and run it up and down the zipper a few time to both sides of the zipper it will make it slide with ease
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
villemitikka 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 6,449
