How to fix water damage
Camera fell in water
좋은 질문입니까?
Hi,
As you know liquids and electronics and electricity are not a good mix.
The liquid causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
First do not turn on your camera and then you need to remove the battery as soon as possible from the camera to minimize further damage.''
Then you need to dis-assemble the rest of the camera and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a link to the Ifixit's guide(s) on how to repair your camera. These are helpful as they show how to dis-assemble the camera so that you can clean it properly.
If this process seems too daunting, take your phone to a reputable, professional camera repair service and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 2,027
