주요 콘텐츠로 건너뛰기
The Acer Chromebook C710-2847 is part of Acer's line of low-price netbooks running Google's Chrome OS. The devices are simply constructed needing just one screwdriver to take them apart.
20 질문 전체 보기
Laptop fell apart- How to repair?
My laptop's casing around the screen and base of the laptop is starting to come apart. I am wondering if there is any easy way to fix it- besides duct-taping the entire thing- which is probably a bad idea!
Here are some pictures of the current issue.
Part of the piece in the back that helps the laptop close/open has broken off.
I am also unable to close the laptop.
is there anything I can do to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
@solarixsy , Solarisxsy , That really is in rough shape. I think your best bet would be to try and find a good used parts machine on Ebay, Amazon,Craig list, etc., and transferring parts to fix. Duct tape is not a perfect idea, looks like some one already was doing this and it might hold it together until you find replacement parts. Find below a couple disassembly guides that may help when you get some replacement parts. Good luck.
Acer Chromebook C710-2847 Screen Replacement
Acer Chromebook C710-2847 Hard Drive Replacement
Acer Chromebook C710 Hard Drive 이미지
안내서
난이도:
조정
3 - 5 minutes
Acer Chromebook C710 Screen 이미지
안내서
난이도:
조정
20 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Solarisxsy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 480
