주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
No response no power and burned components
Received this device as part of a deal and it looks as if someone has already opened it up before. Once opened the first thing I noticed was visible burns in multiple. The lightning port cables onthe left side are burned, looks like a short. Antenna is significantly burned and a small component underneath it is also completely melted through, not sure what that piece is but it is connected to the underside of the logic board and looks like it is just a cable. The biggest of my concerns is at the highest point of the board there is a cluster of resistors which is burned, there should be five side by side, and one is gone. What steps should I take and in what order to repair this. Device has clean imei and lcd looks fine. I also noticed the front camera, and earpiece need replacement. All help is appreciated, my experience consists of screen and home button repairs.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
This is what a phone looks like after someone puts it in the microwave after being dumb enough to follow Internet advice. Not repairable.
If you wanted to waste time and money you could start with changing Tristar and Tigris chip and putting Board with known good battery, charge port and screen. Likely a waste of time.
Jessa
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
If i were to get a complete working 6+ board (activation locked), and swap the major chips from this board onto the locked one it would work, correct?. I have done a little research and it seems like the baseband and nand chips would have to be swapped in order to keep matching numbers. Does this sound correct to you?
Swapping chips do not make economical sense, especially if you are trying to actually repair it instead of recovering data. Plus with the scorch marks, it is likely that EVERY important chip in this thing is shot.
댓글 달기
가장 유용한 답변
@kjt930 first you have to clean it so you can get a better idea of what you are looking at. I also recommend that you add some images of the damage with your question. Use this guide for that. It will allow us to see what you see. To clean your board use this guide for the removal. After you have the logicboard out, you must remove all the EMI shields. If you do not, you won't get your board properly cleaned and may miss further component damage. Then use this guide for the cleaning. It was written for a iPhone 3G but all the points made are still pertinent to your phone as well. Once you have all that check for further damage and you must consider replacing burnt components that are minuscule and require special tools and skills to do so. Of course you will also need a new battery besides all the parts we may identify once you post some images.
iPhone 이미지
안내서
Repairing iPhone Liquid Damage
난이도:
어려움
1 - 2 hours
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
iPhone 6 Plus Logic Board 이미지
안내서
iPhone 6 Plus Logic Board Replacement
난이도:
운영
40 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Thank you, I have removed and cleaned the board and added pictures. As you can see in the picture there is considerable damage to the one segment of the board, if it is possible to repair that I am confident in taking on the project given the right info. If it is not possible, let me know what options you think I have that may be more cost effective than a brand new logic board
@kjt930 there is definitely widespread heat damage. This board might be good for practicing but a full repair is very highly unlikely. You can always try, just do not get your hope up to high.
댓글 달기
Either this thing got the chair with its owner or someone tried the microwave nonsense.
With this amount of energy gone through the board, I have practically zero confidence you can find any salvageable parts, let alone reviving it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Kevin Tulloch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 445
