주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Shark Rocket HV301은 300 시리즈 진공청소기의 두 번째 모델입니다. 다양한 부착물이 포함된 투인원(2-in-1) 진공청소기로, 여러 표면을 청소할 수 있습니다. 세련되고 가벼운 디자인으로 가정 내 어디서든 쉽게 움직이며 청소할 수 있습니다.
Brush Roll Not Turning On
The brush roll will not turn on at all anymore. There seems to be no power getting to it. If I take the stick part off and attach it directly to the canister, it works. Do I need to buy a new stick? Where can I get one?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 7개
The Underestimated seems to be right in my case, although, the female connection (on the motor part of mine, rather than the stick) that is the problem, is not cluttered with debris. Rather, it seems to be missing the connection piece altogether. The hole is just empty. Ugh…what to do now…
의
I hve this problem and shark are not interested. So stick shark dyson has better aftersales
의
I have a rocket hv380 it dosent have a belt on this model but rollers not turning can't work it out any suggestions please
의
It worked!!!! Thank you to the person who answered!
의
Same here with lint covering contact on stick. Thanks
의
댓글 2개 더보기
댓글 달기
답변 5개
선택된 해법
Hi,
It may be that the brush roll drive belt is broken.
Here is a link to the ifixit guide to repair / replace the brush roll. The belt is shown clearly in Step 8 of the guide.
If it is broken then here is a link to suppliers of the part.
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 6
댓글 1개:
But before you do this try the solution below it can save a lot of heartbreak, money and fiddling about!
의
댓글 달기
가장 유용한 답변
You probably won't need a replacement part. I would start by checking the connections on the female side of the wand. I believe you will find that one more of the connections will have foriegn matter covering the contact points causing the problem. Please make sure your vacuum is unplugged from the power source before you clean the connections. Your welcome!
이 답변이 도움이 되었나요?
점수 8
댓글 9개:
This was exactly my issue- I had to use a needle to clear out the gunk (after unplugging of course!) and after a few minutes I could see a clean connection again. Worked like a charm. Thanks!
의
Thank you so so much! You absolutely fixed it - I got a flash light and looked at the female connections on the wand and one was completely plugged. We often use the wand only to pick up pet hair in nooks and crannies - now I know to also clean out the connection. So happy it works again - Thank you !
의
Love Shark Sweepers! My Shark Rocket Duo has never let me down! Today, I went to use it and the green suction light turned on, the roller brushes would not turn. I looked up your site and examined the female connections under a bright light and saw one to be clogged. I took a needle and moved it around to loosen the debris, put it back together and it runs great! Thanks so much! I took a picture, but, do not see a way to load it to help others with the same problem!
의
Words cannot express how grateful I am to the person who put this resolution on this site. I bought two drive belts for my machine then I found this post thankfully before I tried to replace them. My shark rocket is working better than it has in a long time THANKYOU!
의
Great tip! This was my issue also. I’m so glad I saw this before I started to disassemble everything.
의
댓글 4개 더보기
댓글 달기
you have a loose wire in the extension handle part.
uplug the vacuum.
open up the handle and repair the torn / broken wire.
be sure to cover with electrical tape.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for the answer except it is hard to know where on the handle it should be opened up. Pictures would be nice, but if not at least a good description of exactly where to open up. Thanks!
의
anybody have an answer? I cant get this to come off
의
댓글 달기
I had the same and I contacted shark and they sent a replacement foot part free of charge.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Did you have to show them your reciept? I've lost mine and can't use the warranty due to that.
의
댓글 달기
Carrie, did you try The Underestimated answer? I had the exact same problem as you, and when I checked the female connection on the wand it was badly clogged. Cleaned out, and my now works. Good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Carrie Pandya 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 11
지난 7일: 85
지난 30일: 513
전체 시간: 63,367
